SAF IPPT, IPT & RT Questions...
freedom-strike
Just took my ippt today, for the first time i got a "Pass" instead of "Pass with incentive".
Having a "Pass" is as good as having "Pass with incentive", right? Instead of failing.
THFC78
Only diff is that Pass with incentive got $200
flowerpalms
If you dun want the money can give me
firezblade
Trace together token rejected and my old phone cannot install the trace together app. Hence I cannot take ippt / ipt. Anyone in similar situation? Are there any other arrangements available? Any advice apart from buying a new phone?
desmond_yee1
why token rejected?
Nuclear Boy
I suspect maju fcc do not have the scanner for the trace together token.
The last I was at Khatib FCC last month, there wasn't a Safe Entry scanner as well. They were checking TT status by eye. Not sure about now, though I doubt it has changed.
firezblade
Yes, so i am looking for alternatives to check in for ippt since TT apps cannot be installed on my phone and TT token is rejected
Zetrio2006
Ask NS.sg to carry over our fit sessions to next window. Everyone go send a feedback to nS.sg
So this window you can complete 4 sessions, next window complete 6 sessions etc.
Calander
token rejected? change token la. What other advice you are looking for? Plea and kneel to the supervising to allow you to participate? and any issues call NS hotline and ask your unit to get back to you on what to do
life_is_crazy
That was the case in Kranji FCC as well. We were told to fill in our particulars on the SAF Entry website instead of trace together app and the FCC staffs will check our vaccination status on the trace together app before the start of IPPT.
Zetrio2006
Actually, it's because the FCC needs you to answer some other questions as well... If they ask you to scan in on tracetogether, that's 2 sign ins on 2 platforms but TT don't have questions.
