Samsung Galaxy S20 Fan Edition, better than Note 20?
shager
Been using S20FE for 2 months. No ghost touch. All is good. Hope it remain this way
Thanks for the feedback, bro. Picked up a set today and it seems fine with the latest firmware. Mfd date is 2021. Tried with up two 2 finger swipe. Seems to register.
teckwee
Hi hi!
May I just check with you if you got your set from Telco, Challenger, Samsung direct or from some other seller?
Thank you! :)
shager
Hi hi!
Thank you! :)
Red white mobile. Navy. So far all working fine. Mfd date Jan 2021 according to phone info.
lousydrinker
recently i so into the green color that IP12 n S20FE got, just makes me wanna buy either phone
ah_cleo
May i ask how do u guys do test to check if got the infamous ghost touch?
shager
And a few others. This one shows the 3 finger test very well. 😁
Tried it on my OnePlus 9 Pro then saw 3 finger touch has issues. Then realized my screen shot 3 finger gesture is enabled 😂🤣. Make sure gestures are off otherwise it will influence the test.
simon_84
can just use the default test to try out.
there is a touch section to play around with.
meowwy
Something to share here.
My FE bought in April.
After an update in May, ghost touches did improve, but still have minor issue.
Not affecting my daily use though.
Can't say the same for others on gaming.
Experimented with slightly different tests from the 2-finger fast swiping.
Just did simultaneous finger taps to simulate multi-touch.
From the above images, you will see the erratic touches/swipes only appear when only doing the 3-finger taps.
It is not even present when doing 4 or 5-finger taps.
This is so weird.
Did the same tests on my S5, absolutely no problems at all.
Someone else should try on your sets and share.
Edit: 3-finger tap errors are more pronounced when the 3 tap positions are aligned vertically. Zero errors for me when the 3 tap postions are further apart or aligned diagonally.
ah_cleo
I got mine last sat.. default oct 2020 security patch. Did all the updates den clone in my data. So far 3 touch all ok. But weird is i use original samsung 15w charger, have abit of phantom touch.
My manufacture date is 2021-02-02
grasscut
S21 or S20 FE? which one would you guys recommend? S20FE still got touchscreen issue?
