set it to Maximum 10 hours ago, just meet the very first crash and reboot ever since I got the phone when use AlipayYa! Snappier for sure! If you set the Battery to "Maximum" from the default "Optimized"! It is even snappier for all apps.
I set it to "Maximum"!![]()
Wa i thought I'm the only person experiencing this problem these few days. But I'm on Singtel. I been reading around seeing anybody report this problem or not. I have to disable my 5G.Anybody got issues with starhub 5g network? Seems like random dropping of the whole mobile network, without any Internet at all or even sometimes phone calls. Especially when moving around SG. I'm not saying from 5g drop to 4g. I mean it totally cuts of Internet with no data or even sometimes drop network.
If set to 4g lte only, no issues, stable connection.
Do you also have issues when set to 5G like:Wa i thought I'm the only person experiencing this problem these few days. But I'm on Singtel. I been reading around seeing anybody report this problem or not. I have to disable my 5G.
Not too sure if it was due to Maximum!set it to Maximum 10 hours ago, just meet the very first crash and reboot ever since I got the phone when use Alipaynot sure if its because Android 12 or the Maximum
So better to just fix at 4g lte instead.I'm on M1 5G SA!
Same same lah!At those so called "border" areas between 4G and 5G. My mobile data can get stuck and lost totally too since day one!
Same like you all! I have to switch to 4G in order to recover my mobile data connection!![]()
Yes I have this same exact problem.Wa i thought I'm the only person experiencing this problem these few days. But I'm on Singtel. I been reading around seeing anybody report this problem or not. I have to disable my 5G.
Oh. Then can u explain why previously was ok?I'm on M1 5G SA!
I set the maximum and let it run for a day already, the only thing i experienced was that i can feel the warmness from the phone. Otherwise still ok for me. Odined with germany version of Android 12 while using home_cscset it to Maximum 10 hours ago, just meet the very first crash and reboot ever since I got the phone when use Alipaynot sure if its because Android 12 or the Maximum
It's normal as it was switching antenna from area to area. I'm on M1 5G on my iPhone 12 Pro Max and Singtel 5G on my S21 Ultra.Anybody got issues with starhub 5g network? Seems like random dropping of the whole mobile network, without any Internet at all or even sometimes phone calls. Especially when moving around SG. I'm not saying from 5g drop to 4g. I mean it totally cuts of Internet with no data or even sometimes drop network.
Can confirm it's Alipay not compatible with Android 12. tested that it will also reboot if set to Optimized and use AlipayNot too sure if it was due to Maximum!I don't use Alipay and I don't play games with my S21+!
You probably wanna set it back to just "High"...![]()
Switching I know, but sometimes it didnt switch successfully and it either not have mobile data till i manual off and on mobile data, or drops all network for a short frame.It's normal as it was switching antenna from area to area. I'm on M1 5G on my iPhone 12 Pro Max and Singtel 5G on my S21 Ultra.
Hmmm, i guess it's still the same. Maybe M1 5G network which i'm using for my iphone 12 pro max is not good yet because I didn't encounter this issue yet on my S21 Ultra. Seem like Singtel 5G coverage almost everywhere for me.Switching I know, but sometimes it didnt switch successfully and it either not have mobile data till i manual off and on mobile data, or drops all network for a short frame.
iPhone seem to have stronger network and seamless switching right?
Could also be carrier services on Google store. Cause I noticed it doing that after updating it at one point. I could be wrong though but try switching off WiFi calling. It seems to reduce alot more doing that.I read in samsung community, a lot says it's after the latest fw updates.
