Samsung Galaxy S25, Edge! FE! Ultra! & Accessories ..
What do you think is the nicest color S25 series?
  • Total voters
    202
kashix
Just a simple test
Broadcom chip based router, will try Qualcomm one tomorrow
@Jurong640
@Fellowes For your ref, S25 Ultra ...
hub8246
This is normal only leh ... I hit almost 4.2Gbps on Xiaomi 15 liao ... OP13 easily 4Gbps. This one smell no smoke ...
I thought all these devices are using sd8 elite chip. Should have same WiFi capabilities.
Unless Samsung is limiting the speed which is unbelievable.
kashix
Samsung there’s some wifi saving setting enabled by the OS, you can try. You speed test a few times the speed will gradually get faster and faster, like need to warm up. Xiaomi is never pull hand brake, it goes all the way to max. OnePlus around 4.xGbps.
C32B
What cleaning apps do your use ? I using CC Cleaner but need activate through "Accessibility" section every time I need.
rinchan22
Not using any. Samsung already have the default cleaning widget that you can use that although cleaning apps are not necessary 99.9% of the time.
gapboy
i used to used sdmaid also alot restrictions since android 15. I have stop using now on samsung phones
C32B
Thanks for that. I missed on the default cleaning widget. Except cache files have to do it individually.
eq2addict
yeah , i'm just using the samsung cleaning app. it finds duplicated files and large files as well. not bad.
eq2addict
Had issues with Google pay also. Reader cannot detect even when Google wallet app is opened. Switched to Samsung pay now better. Think it's a one UI 7 issue.
yeah i notice my fold5 also detect much faster .
the s25u much slower. zzz .
eq2addict
Is it the one in the setting under "Device care" ?
my files -> manage storage , then it will have options to show duplicated files , recycle bin , large files , review old files ( whether u want to delete or not) unused apps etc etc
u can click on the arrows to see what files in each category n delete also.
C32B
Thanks for the direction. It performed the same functions as "File Manager +".
kreja
Regarding sc+:
If buy from other stores like shopee or telco,
How do i buy sc+?
Is sc+ tied to my samsung account?
Does that mean i need to log in my samsung account on my family member phone to get sc+ for his phone?
