Manually copy the <internal storage>/Android folder over?any solution to transfer APP DATA from old device, poco x3? tried the smart switch to smart switch, it doesn't work.
Yes. I turned on the protect battery option in Settingsfor a moment I tot ur SOT quite similar to mine. only when I reread your post then I realised battery discharge from 85%
your battery life better than mine.![]()
doesn't work. anyone here rooted the z fold? how many of you purchase 2nd year Samsung care+ ??
Do you know is there a time limit before you need to buy the second year coverage? I wanted to extend my one year care+ tooI suggest you setup the device from scratch. It's a pain but this is the most guaranteed way of making sure your device works well. Copying internal files from one Android device to another will/might cause a lot of orphaned files to wreck havok in your new device.
Rooting the Fold 3 will disable the cameras - https://9to5google.com/2021/08/24/g...all-cameras-while-the-bootloader-is-unlocked/
I purchased a 2nd year of Care+ as I intend to use my phone for 2 years.
Think better careful here. 30 days is to take up free 1st year offer. Not sure whether it is the same as buying sc+ which has to be done within 14 days. (When you go for the 24 months, it is like buying).decided not to root as I was able to get the app data sorted. I probably will buy the 2nd year as well. i see inside the samsung member app shows 29days left to sign up. time limit should be 30days? 14 days is for signing up SC+
This one looks hideous.![]()
Samsung W22 5G officially announced in China
A customized version of the Samsung Galaxy Z Fold3 for the Chinese market arrives starting at CNY 16,999.www.gsmarena.com
Premium Gold Fold 3 16GB+256GB for CNY 16,999 (USD $2,645).
So......... only the hinge is Gold and with the special logo at the back.........oh, and the S Pen with the small gold ring at the top of the S Pen.........![]()
Will it peel off easily? Have checked with ahbeng shop, they said will as open and close ....$10. Xgear at waterway point
Considering a month+ fold 3 at $1800. Condition like new according to seller. No extra accessories. No screen protector applied. Good deal?
No screen protector? I thought screen protector is standard from factory? Maybe be cautiousConsidering a month+ fold 3 at $1800. Condition like new according to seller. No extra accessories. No screen protector applied. Good deal?
I think the factory screen protector should still be intact. Does outer screen come with factory screen protector as well? Another question is the seller did not register warranty. It’s fine right? Samsung probably activated the warranty when the phone started being in useNo screen protector? I thought screen protector is standard from factory? Maybe be cautious
256gb. Ya, it’s a dilemma…How many GB? Now 256GB brand new without freebies are going for $2098
Samsung Z Fold 3 5G 256GB | Red White Mobile
Available in Black Samsung SG Warranty Setredwhitemobile.com
