Seasonic psu and b450m vdh max replacement
jellyboy
Suspect either my seasonic psu are spoilt or my 2mth old mobo is. Cpu fan turns off then screen turned black, audio got cut but system fans were still spinning. Upon restart, cpu fan still couldnt turn on but switching the connector to another header worked. Then the same thing happened again.
Can I get a replacement on the spot for both these items if i bring it down tomorrow?
Sent from Samsung SM-G973F using GAGT
clon22
Suspended
Hi there,
You can bring the mainboard and psu down for a check.
Let our guys take a look @ it first and their advise from there. :)
jellyboy
Got a replacement for the psu on the spot. Tech also helped me test the board to make sure it was working. Went home, set it all up and its been working fine since then! It was really just the psu after all. Thanks for the help! Glad both items were from same distributor �
