small issue with Dell u2415 monitor using hdmi
sacredrays
Some time when I off on appliances within my house my screen will just go black for 1-2 sec before recovering. This happens when I use hdmi input (tried both input also same) but I think it doesn't happen when using dp (only tried for a while on my bro comp). I also tried using my monitor elsewhere while still connected using hdmi and able to get the same issue...
I contacted dell for warranty support and is waiting for replacement to come.. just wondering if anyone also suffer from this issue? or anyone knows why?
Gribber
change the HDMI cable? Use a surge protector?
yusoffb01
Change switches in your house. Its too old and create ripple when u switch off. Replacement will have same problem
kandinsky
Is this monitor plugged to a power strip/extension? You can try plugging directly to one socket (no other devices/extension) to see if the issue persists. You can also try testing it with all the other available power outlets in your house.
It happens to my 2nd monitor also. I think it's got to do with the circuitry of the house/powerstrip, nothing to do with the monitor.
It's not uncommon.
See this thread:
your house wire is old, happens to me also.
if someone off a switch my monitor will go black (rare) but happens
sadly. unless you re-wire your whole house, nothing much you can do
sacredrays
i used surge protector also same. and yea, replacement monitor same problem also. now worse cause got 3 dead pixels on the screen.. sian.
anyway i also tried plugging to other places as well as changing cables.. also same issue, only when using dp (on my bro comp) I can't seem to replicate the problem.
Gribber
UPS then.
10chars
wolnavi
Dunno if related but my tv also like that, Google the problem and found out it was the old wiring in the house, and because of the old wiring, whenever I on a light in the house, the TV will also blink or blackout for 1-2 secs. According to the Google result, the light gives out a lot of emf radiation or smth like that so that's why, can try change to led lights or call electrician to see the house wiring maybe need replace?
sacredrays
wish I asked earlier.. replacement monitor same issue but with 3 dead pixel, one small 2mm weird slightly colourful line and also slightly yellowish compared to my old monitor.. should have sticked to my old monitor instead.
The thing is that if I use displayport instead, don't have the issue, only hdmi... why sia...? my comp gfx card no dp though.. only my bro one have.
MoneyFace =p
Not this one ar FYI....
UPS is backup power supply in case mains power supply trips....
wolnavi
Not very sure but is the displayport cable shielded? Maybe it's shielded so the emf radiation won't affect the electrical signals sent through the dp cable compared to the hdmi cable
sacredrays
no idea man.. i tried using displayport cable that was included with the monitor, no problem.
Basically, my brother have a u2515h connected using mdp to his comp, no issue. Even when I swap to my monitor also good. But once I use hdmi (I tried 2 different cables), the problem came about, my bro monitor also suffer from the same issue too.. too bad my gfx card no dp port, sad...
MoneyFace =p
Probably cheap HDMI cable bah cos i also encounter such problem on my TV. Problem solved after switching to AmazonBasics cable from UFO one...
sacredrays
anyone gotten a new monitor as a replacement monitor? just arranged for delivery for another replacement monitor because of screen quality issue but a bit confused cause the guy over the phone said it is refurbished then after a while say its brand new.. :s22::s22:
jayz89
My house also like that, on off kitchen lights will kena
Old hdb is like that
radiancez567
get shielded cable can liao i think.
Hi sacredrays, so how did you solve your problem eventually?
Just bought a monitor and this problem is happening to me.
Laptop -> HDMI (1m unshielded cable that cost only $5) -> monitor
Invest in a good quality cable?
