TanKianW
- Apr 21, 2005
1) Try untag VLAN10, "not member" VLAN30, PVID 10,
Assumption: you want to achieve AP with VLAN10 IP address, client connect also with VLAN10 IP address
2) Try "not member" VLAN10 and 30, PVID 1.
Assumption: you want to achieve AP in default VLAN, client connect also on default VLAN.
3) Try tag VLAN10, "not member" VLAN30, try PVID 10 or 1? This one I am unsure coz I have no idea how the router mode work. Only trial and error.
Not sure if it will work since I am clueless with the ST Mesh router. Worth a try.
Singtel Mesh Router Test Results -- no power cycle of the router this time to see how it goes. Client side will disconnect and then connect the Wifi to refresh the DHCP process.
Testing sequence: initially connect to Port 6 and working as expected. Then move to the next 4 tests in sequence.
1) Port 2: Untagged VLAN ID 10, PVID =10
Expected: 192.168.10.x IP address for both the router and wireless client
Results -- initally RED LED but later recovered and work as expected.
2) Port 3: Untagged VLAN ID 10, PVID =1
Expected: 192.168.28.x IP address for both the router and wireless client
Results -- as expected
3) Port 4: tagged VLAN ID 10, PVID =10
Expected: no internet access for the wireless client
Results -- initially as expected, RED LED on the router and client can not connect to the netwok but later recovered. It is working in router mode and it can get an IP address 192.168.10.x (for VLAN10) from pfSense. Wireless clients get 192.168.1.x address from Singtel Mesh router.
4) Port 5: tagged VLAN ID 10, PVID =1
Expected: working in router mode and WAN address of 192.168.10.x IP, wireless clients will get 192.168.1.x address from the router.
5) Going back to Port 6 -- I need to power cycle to get it work again: AP mode, 192.168.28.x IP address for both the router and wireless client.
I will try the next test -- power cycle the router after changing the port connection, to see if the results are different or not.
Between (3) and (4), you should use (3).
(4) is applicable in situation where you have an AP which has VLAN management capability, when you set the PVID at default [1], the AP admin page (on DHCP) will stay in on the default [1] VLAN but you could connect your devices on that AP tag to another VLAN.
Thanks for the advice.
Actually you can consider Singtel Mesh Router to be an Router/AP with VLAN management capability (but as a black box which you can not change). I think this becomes more as an exercise to reverse engineering the behavior of Singtel Mesh router VLAN behavior.
Probably I should concentrate more on the testing with the Huawei AX3 Quad Core version in AP mode to understand better the usage of VLAN ID and PVID. Huawei AX3 Quad Core global version also has VLAN settings for both router mode and AP mode (VLAN ID and PVID). I will test it as well. It is a surprise to me that this cheap AX router has this capability. The China version Huawei AX3 Pro (more expensive) does not have this capability.
Then I have the MikroTik hAP ac2, which has VLAN management capability as well.
I have also OpenWRT capable wireless APs like the Linksys EA7500 v2 and WRT1900AC V1. They also have VLAN capability.
You can see I have many "cheap" networking stuff and I am trying to utilize them for my learning of Networking related subjects.
Or maybe I should buy a proper managed switch like those from Unifi or MikroTik (budget is below S$200). But I guess this TP-Link is a good one to start before I move to higher end stuff. I am still hoping to use the MikroTik hAP ac2 as a managed switch. I do not care too much about performance as of now.
For VLAN functions, you do not need a complicated managed switch (like MikroTik RouterOS), the TP-link switch should suffice, without diving into the nitty-gritty. It will achieve what a home consumer need 99% of the time. Even for the application I describe above.
Recently I also just set up an 8 port TP-link switch (connecting to 2x 2nd hand APs I gotten from TB) for one of my family member new place. It is serve its purpose really well without hiccups.
Some data:
1) pve Speedtest is normal
2) pve to pfSense VM iperf3 degrades a bit (pfSense slower Rx)
3) pve to pfSense VM LAN client degrades further (pfSense slower Rx)
pve host -- 192.168.28.216
pfSense LAN -- 192.168.28.1 (iperf3 server)
Debian 11 pve VM -- 192.168.28.133
Windows laptop physical client -- 192.168.28.132
root@pve:~# ./speedtest -s 25960
Speedtest by Ookla
Server: Singtel - Singapore (id = 25960)
ISP: Singtel Fiber
Latency: 1.11 ms (0.12 ms jitter)
Download: 945.10 Mbps (data used: 449.6 MB )
Upload: 946.37 Mbps (data used: 1.1 GB )
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/1052bfe1-dfde-4df7-addc-9f2767be1cbe
[2.5.2-RELEASE][root@pfSense.home.arpa]/root: speedtest -s 25960
Speedtest by Ookla
ISP: Singtel Fiber
Latency: 1.41 ms (0.08 ms jitter)
Download: 751.51 Mbps (data used: 1.3 GB )
Upload: 741.85 Mbps (data used: 739.9 MB )
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/0ed17548-b31a-4df6-9263-a0a7ebb34ce7
PS C:\work\speedtest\ookla-speedtest-1.1.1-win64> .\speedtest.exe -s 25960
Speedtest by Ookla
ISP: Singtel Fiber
Latency: 2.15 ms (0.22 ms jitter)
Download: 748.45 Mbps (data used: 526.2 MB )
Upload: 858.19 Mbps (data used: 1.0 GB )
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/4dcc01f7-daea-4576-928d-b68dbd09ea4b
[2.5.2-RELEASE][root@pfSense.home.arpa]/root: iperf3 -c 192.168.28.121
Connecting to host 192.168.28.121, port 5201
[ 5] local 192.168.28.1 port 21978 connected to 192.168.28.121 port 5201
[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 133 MBytes 1.12 Gbits/sec 5 3.00 MBytes
[ 5] 1.00-2.00 sec 134 MBytes 1.13 Gbits/sec 0 3.00 MBytes
[ 5] 2.00-3.00 sec 119 MBytes 994 Mbits/sec 0 3.00 MBytes
[ 5] 3.00-4.00 sec 92.1 MBytes 772 Mbits/sec 5 3.00 MBytes
[ 5] 4.00-5.00 sec 105 MBytes 883 Mbits/sec 1 3.00 MBytes
[ 5] 5.00-6.00 sec 127 MBytes 1.06 Gbits/sec 1 3.00 MBytes
[ 5] 6.00-7.00 sec 129 MBytes 1.08 Gbits/sec 0 3.00 MBytes
[ 5] 7.00-8.00 sec 129 MBytes 1.09 Gbits/sec 0 3.00 MBytes
[ 5] 8.00-9.00 sec 132 MBytes 1.11 Gbits/sec 0 3.00 MBytes
[ 5] 9.00-10.00 sec 138 MBytes 1.16 Gbits/sec 1 3.00 MBytes
[ 5] 0.00-10.00 sec 1.21 GBytes 1.04 Gbits/sec 13 sender
[ 5] 0.00-10.36 sec 1.21 GBytes 1.00 Gbits/sec receiver
iperf Done.
[2.5.2-RELEASE][root@pfSense.home.arpa]/root: iperf3 -c 192.168.28.121 -R
Reverse mode, remote host 192.168.28.121 is sending
[ 5] local 192.168.28.1 port 58539 connected to 192.168.28.121 port 5201
[ 5] 0.00-1.00 sec 115 MBytes 961 Mbits/sec
[ 5] 1.00-2.00 sec 120 MBytes 1.01 Gbits/sec
[ 5] 2.00-3.00 sec 119 MBytes 999 Mbits/sec
[ 5] 3.00-4.00 sec 125 MBytes 1.05 Gbits/sec
[ 5] 4.00-5.00 sec 120 MBytes 1.00 Gbits/sec
[ 5] 5.00-6.00 sec 125 MBytes 1.05 Gbits/sec
[ 5] 6.00-7.00 sec 120 MBytes 1.01 Gbits/sec
[ 5] 7.00-8.00 sec 120 MBytes 1.01 Gbits/sec
[ 5] 8.00-9.00 sec 119 MBytes 1.00 Gbits/sec
[ 5] 9.00-10.00 sec 117 MBytes 984 Mbits/sec
[ 5] 0.00-10.36 sec 1.17 GBytes 974 Mbits/sec 12 sender
[ 5] 0.00-10.00 sec 1.17 GBytes 1.01 Gbits/sec receiver
iperf Done.
PS C:\work\speedtest\iperf3.10.1_64bit> .\iperf3.exe -c 192.168.28.121
[ 5] local 192.168.28.132 port 53578 connected to 192.168.28.121 port 5201
[ 5] 0.00-1.00 sec 115 MBytes 965 Mbits/sec
[ 5] 1.00-2.00 sec 113 MBytes 949 Mbits/sec
[ 5] 2.00-3.00 sec 113 MBytes 949 Mbits/sec
[ 5] 3.00-4.00 sec 113 MBytes 949 Mbits/sec
[ 5] 4.00-5.00 sec 113 MBytes 949 Mbits/sec
[ 5] 5.00-6.00 sec 113 MBytes 949 Mbits/sec
[ 5] 6.00-7.00 sec 113 MBytes 949 Mbits/sec
[ 5] 7.00-8.00 sec 113 MBytes 949 Mbits/sec
[ 5] 8.00-9.00 sec 113 MBytes 949 Mbits/sec
[ 5] 9.00-10.00 sec 113 MBytes 949 Mbits/sec
[ 5] 0.00-10.00 sec 1.11 GBytes 951 Mbits/sec sender
[ 5] 0.00-10.05 sec 1.11 GBytes 946 Mbits/sec receiver
iperf Done.
PS C:\work\speedtest\iperf3.10.1_64bit> .\iperf3.exe -c 192.168.28.121 -R
[ 5] local 192.168.28.132 port 53583 connected to 192.168.28.121 port 5201
[ 5] 0.00-1.00 sec 113 MBytes 952 Mbits/sec
[ 5] 0.00-10.05 sec 1.11 GBytes 946 Mbits/sec 0 sender
[ 5] 0.00-10.00 sec 1.11 GBytes 950 Mbits/sec receiver
iperf Done.
Probably the most popular, since it's cheap enough, compared to Ruckus.pfSense + Unifi switch + Unifi AP seem to be a popular combination.
Simple tutorial:
He actually moved from UDM Pro to pfSense.
Unifi routing products are sorely lacking for what they charge...Probably the most popular, since it's cheap enough, compared to Ruckus.
Says a lot about the Unifi gateways.
Also says a lot about Omada, since many Americans are particular about their tech - and the adoption for Omada remains low despite being in the market long enough. My personal experience with it concurs - okay to try, but not stay with the platform. To be blunt, it might just work for the typical Singaporean who does not care for security and all; those who depend on ISP supplied hardware and then not bother about it once set up. I think it'll make a decent AP network to pair with the ONR.
That's true. But I'm comparing against consumer gear, the likes of Asus' top end models.Unifi routing products are sorely lacking for what they charge...
Heck, as a power user I don't think I will buy their routing products even for $100 in it's current state.
Does anyone face a memory leak issue? My J4125 with 8Gb memory.
On booting up typically only 18% memory usage. After 4 days of usage, with lots of openVPN involved, memory usage has crept up to 65%!!!
