Tire in JB VS SG
trd2970
Pls check the tyre manufacture date. The four digit code can be found on the sidewall. Normally in a "box". 3814 means 34th week of 2014.
cavie
Just patch a punctured PS3 tyre. The shop suggest to change 2 or 4 tire to balance the tire. The car is now left with one year, so wonder if (1) change one tyre or (2) change 2 cheap tires at JB. Would there be big issue? TIA
yanbros
What size. It will only be cheap if its 15", anything bigger, change in SG.
pew
Some Cheap places don't come with free rotation...which is about $40 liao
coolrookie
Changed PS3 in SG S$135/PC (include balancing without alignment). Made in Spain. jb quoted same PS3 but made in Thailand RM 395/PC (balancing, alignment). Took up Sg offer, never regret, now F1 with my PS3 in Sg highway. Pushing other cars.
AL5509
If I am you, will change in JB as made in Thailand PS3 is a better deal.
As what you changed is PI tyres(PS3) which it's sidewall is softer thou.
Apart from that, I think some JB tyre's shops will include free alignment too(that is what I did too).
Anyway enjoy driving and respect the road together with other road users too.
Happy New Year ya
croc1977
europe model is use for european climate while sea made is asean climate...
ex doesn't mean good
jumpmanz
That JB made in thai is a good deal. changed 2 months ago for 16" cheapest i found also 140/pcs.
Sent from my Samsung 4K HDTV in Batam using GAGT
mypillowtalks
Changed in johor jaya
Used to use Yokohama Geolandar SUV @ RM510/piece
Recently try Bridgestone Dueler H/T @ RM500/piece
Bridgestone Dueler A/T only RM510/piece.
Too bad current 225/65R17 already rubbing against body, maybe will be grinding off the body to fit it in the future to fit the A/T. :s13:
Beepok
Wow rich....I get Achilles hawk rm400 haha but mine is for 235/55/r18. The front is Dunlop D05 rm480. No need so good tyres for cx7 lol
akira7sendoh7
Bro where you change and how many inch. Mine 17inch got quoted 165 but manage to press to 160 without alignment. Consider ex or not?
kenstyle
Hi, I am also looking for tires. In SG :
1) Geolander SUV is $170
2) Geolander HT is $189 (no stocks)
3) Hancook HP is $140
4) Maxxis HT is $150
Am finding out if Maxxis HT would be cheaper in JB.
Went JB a few days ago was introduced to Toyo UP tires. Selling about SGD$130 with balancing included
AL5509
https://www.bridgestonetyres.com.au/potenza-adrenalin-re003
just check this tire vs my PS3 which one better?
last month was quote less than RM$900 for 195/55
i need wet grip
I was on PI PS3 previously, which is quite good and served me well on both wet & dry condition.
Am currently on RE003 (made in Thailand); the grip is equally good, but feel it slightly better as it's side-wall is harder (as I do believe bridgestone tyres do have hard side-wall).
So my opinion is whichever is cheaper at that point of time, just go for it.
Hope it helps.
croc1977
Was quoted
Ps3 rm260
Direct 5 rm 24x
Re003 full set of 4 plus trade in rm88x
Good anot re003?
AL5509
Was quoted
Ps3 rm260
Direct 5 rm 24x
Good anot re003?
Guess my feedback isnt powerful enough šŸ˜‚
Will just said, nothing will goes wrong with bridgestone potenza tyres.
