Have you tried to configure the custom IPTV vlan settings?
You need to do some vlan tagging setting in order for your Singtel fibre internet to work.
Best is to call their support.
My neighbor was using the Archer c9 . they need to give him some beta firmware and guide him on the settings.
Did you select "Singapore-ExStream" under IPTV Mode settings?Yap.. did try to custom the IPTV setting but did not work.
Are both your Internet and SingTel TV not working or just TV not working?
You connect router WAN port to ONT port 1?
There is no need to configure other settings if you had selected "Singapore-ExStream" profile. I'm using the same C3200 router with my ST 500Mbps and working fine, including SingTel TV. Kindly see below.Can't remember if select " Singtel ExStream" but i remembe entering the setting as:
Lan 1 : Internet
Lan 2 : Internet
Lan 3 : Internet
Lan 4: IPTV
Both internet & the mio not working.
Have you tried rebooting the ONT after connecting the new router? Can you also verify that a valid WAN IP address was obtained (Network > Internet > WAN Interface) ?
I did not use Quick Setup, 'Exit' there.Bro, tried just now, but still cannot
Just a check, On the quick set up, which option did you select? Dynamic or Static?
And i cannot select the country, it is set default as United States.
Go to Advanced > Network > Internet > WAN Interface > Internet Connection Type: Dynamic IP
After saving, can try to power cycle the router.I click save and nothing happen.
Do I need to click on the renew button?
Also I'd recommend to Off both ONT and Router, power On ONT first, wait till all LEDs are solid/stable green then power On the Router.
Still cannot lei.. could my unit be faulty?
It doesn't seem to be able to capture the IP address.
try pushing the reset button.. it might work..
I think i have reset it more then 5 times le..![]()
There is no firmware available on Tplink website yet for this router model.reflash the firmware, then push the reset button for 10 seconds... then try again..
if not, there might be an issue with your router..
