Upgrading your HDB Home Network to 10Gbe Project
Project_Xco
2) Tested all the Cat6 points around the house and found that 2 out of 6 Ethernet point could not run at 10G. Which may be due to wear and tear of connection point or cable degradation. will get a contractor in to restore these data connection point.
How did you perform this test to find out if they run at 10Gbps?
TanKianW
I engaged a network contractor with the 10G testing gear to test for me. (Unless you are lucky enough to get an electrician who has the gear to do it.)
OR
Run 10G test servers at both ends.
