Potatoes will grow almost anywhere. The yield here will be pretty sh!tty though. There has been research done into GM potatoes that better tolerate heat.not sure if our climate is ok for it
Our climate is too hot for normal taters. They will sprout, but will not thrive or form many roots. Try sweet potato.I tried grow at home before.
not enough sunlight n e potato rot due to moisture.
In our climate better stick to sweet potato and yam. Sweet potato leaves are a good food crop and are an alternative to harvesting the root.
That's right. You want the roots, you gotta wait for the leaves to wilt. And wilted leaves need disposal. You'll be able to harvest the leaves relatively constantly as leaf harvesting doesn't kill the plant. You'll want to do it often in any case as old sweet potato leaf is inedible.for sweet potatoes, once you harvest the leaves, there won't be any sweet potatoes to harvest. if you want the root, you cannot harvest the leaves.
Read HWZ Forum Rules!
