whats the difference between i7 12 gen and i5 13 gen??
rathalos
But my main issues with Intel is that you need some really good cooling solution to cool it.. as the power draw is quite high... so most air cooler are out of the question unless it is those big ones..
How did u think Intel achieve it's performance? By brute forcing it's way through pumping enormous amount of power lo.. more power means more heat..
BlackWing1977
It also has E-cores besides the regular P-cores... that is why it looks different when you compare to AMD.
Ronin881
It depends whether you are gaming or just using it to surf the Net and use a few Office apps.
If you are no gamer, you will not see the difference unless you look at your bank statement.
For most non-gaming users, i3 will do.
