where can i purchase soundproof door?
danny8x8
room has 4 walls besides a door leh.....
robotechnie
its not only about the door, its also about your walls
the soundproof of the walls comes from different materials used in filling the walls. generally the thinner your walls, the cheaper quality is being used (those sort of foam which is easy and cheap to get) - contractors tend to use it for 99 year old buildings
also take a look at acoustic foams that you can get easily online
hope this helps
