Which 43" monitor to get?
Kopi Gao
Dolphin bro: the photo you took of your 55" OLED at a certain angle makes the TV look like not very big like that. LOL.
Did you even consider 65" OLED as one of your buying choices (in case got buyers' remorse)? Also, did you consider other brands of OLED besides LG? Thank you!
joesph
i'm using samsung u28e590 how to get 60Hz on 4K? is it the lousy mazer hub only 30Hz? thank you
joesph
i test with DeX Pad, 2160@60Hz
Sent from Samsung SM-G980F using GAGT
i1magic
Wah lau eh.... 55" and you sit 1m away.... how you tahan the eye strain?
I also thought of hooting Acer 43" DM 431k but I only sit 70 to 90cm away from screen.
Scared if I buy liao, my eyes will be super strained... =(
I almost bought the Acer DM431K but got 2nd thoughts. I am not sure I will like 1 x 43" 4K monitor over 2 x 27" QHD (2560 x 1440) monitor.
Now still undecided.
