Which engine oil best for best long mileage?
ZhuTou!
How many threads u wanna create?
Cannot ask all questions in one thread?
CuteBeaver
Sent from Sent from Iphone 6s using GAGT
eyke81
look for ACEA A5/B5 : Stable, stay-in-grade oil intended for use at extended drain intervals in high performance gasoline engines and car & light van diesel engines designed to be capable of using low friction low viscosity oils with a High temperature / High shear rate (HTHS) viscosity of 2.9 to 3.5 mPa.s. These oils are unsuitable for use in some engines. Consult owner manual or handbook if in doubt.
shared
For my friend's 29 year old car, with over 500,000 km on the mileage, using Liquimoly 20w50 heavy duty diesel engine oil.
smooth as silk.
yamashita
Moderator
Moderator
Paisae. Is it 5w20 most exp de? I ever saw 0w20.i tink. Is it thr best de?
My after servicing dunno wat engine oil they put, now less 100 mileage
You should buy engine oil based on manufacturer's recommended viscosity.
There is an interval for oil change as well. It doesn't mean buying an expensive EO will allow you to go beyond the oil change interval.
karltansg
I still use Mobil 1, think its good for my suv. Dont have issue and wont change for now.
x3dnd3x
Good ah! I saw some with label some with no label, are there any difference actually? :s22:
Different components processed. If Mobil EO, go for the 5W-30 green label, if not the 0W-40 gold label.
x3dnd3x
Gamxia advice. 2 x 0w40 stocked :)
Actually i can get it free lar but if sway, kena caught and ask to leave because of EO damn bo liao. :s13:
Because process liao, not fit for export is dispose. But not fit for export/sale is actually just that minor 0.05% off.
