royfrosty
- Jul 23, 2009
[Project Energy] The battle of multi port chargers (Updated with Nexus 6P Type A to Type C Cable)
Project Energy
Ok after much consideration, i decided to embark on a very tedious multi port chargers testing project. Reason for this project is to check which type of chargers charge different device differently. And also hopefully help some decision making for any users out there looking for a multi port charger.
Why is it tedious? Cause it involves many days of testing on multiple devices on multiple chargers and furthermore the wait of every device hitting near deplete battery level and testing it on all 3 chargers.
Here are the multi port chargers contender.
From the picture left to right:
1. Anker 6 Ports 60w
2. Choetech 6 Ports 60w with Qualcomm Quick Charge 2.0
3. Thecoopidea 5 Ports 55w
4. Aukey 5 Ports 53w with Qualcomm Quick Charge 2.0
More on each individual multi ports chargers
Anker 6 Ports 60w
Anker 6 Ports configuration is pretty standard supplying all ports at 2.4A max each. Using an IQ device detection, it is their terms for detecting any device connected to it and supply the fastest charging capabilities to each devices. However at 60w, this charger will have an issue if you managed to saturate all ports with 2.1A rated devices. Such as 6 iPad Minis or iPad Air etc. For example based on single port testing of 1 iPad Mini 4 took in at 2.03A @ 5.08V gives you 10.31W, if you gonna plug in all 6 ports it will only give you 60W in total. A small sum of wattage will be lost. And hence if the unit is too hot, it will throttle down the performance, and it will not charge at its full potential.
Thecoopidea
Thecoopidea is one of the best 5 Port Charger which is rated as it is. Despite the configuration is slightly different from the rest, it gives a total of 53w max output. It is still very "powerful" why? This charger has 4 Ports rated at 2.4A each out of all the 4 Ports, 1 of the Port is Smart USB charging, and lastly 1 Port 1A. Judging from just 1 Port charging the iPad Mini 4, it takes in 2.15A at 5.10V on Smart Port, and 2.05A at 5.12V on regular 2.4A Ports. This will give you an effective 10.96W + (10.49W * 3) + 5.16W = 47.60W. Leaving you a little more head room before hitting max 53w.
Choetech 6 Ports with Qualcomm Quick Charge 2.0
This charger is really under powered only if you use 2 quick charge 2.0 device to charge at the same time, and not only that, the rest of the 4 ports will not output the maximum capable output. Reason being that in theory, the 2 qc 2.0 ports max output is 36W. For some reason, the other time i tested my Aukey Powerbank which charges 1A @ 12v and Samsung S6 Edge at 1.6A at 8.89V which already hit 26.22W out of 36w that both qc 2.0 ports can handle. Note that it even throttles once in awhile when it is far too hot. And when you have 2 qc 2.0 enabled device charging, and you include a couple of 2A rated device on the remaining ports, it will be boiling hot, not only it will throttle to keep it cool, you will only have less that 9w per normal 2.4A ports. Which will effectively slow down in charging.
Aukey 5 Ports with Qualcomm Quick Charge 2.0
This charger is the smallest among the rest of the charger above. Since this comes with just 1 qc 2.0 port, the total output of this charger is 53W, since it has a maximum of 18W for 1 qc port. Leaving the rest of the 4 ports at 8.75W each, which in turns not really a powerful charger afterall. However if you are just charging mobile devices such as the S6 edge which only takes in a max of 14W, you are left with a rough 9.75W-10W region per port. Which is reasonable and also able to charge any other devices normally if you did not exceed the 14W qc port. And after testing for a few days, i did noticed that this charger is somewhat the most aesthetically inclined product against the rest of the multi ports charger. And lastly it is not as hot as the Choetech while charging. In fact it sits somewhere in between the Thecoopidea and Anker in terms of heat.
Overall outlook of the ports on all multi ports chargers
Testing Analogy
The devices that will be tested:
1. Samsung S6 Edge
2. Xiaomi mi4i
3. Iphone 6 Plus
4. Ipad Mini 4
5. Aukey 15000mAh powerbank with Qualcomm Certified Fast Charge 2.0
6. Samsung Note 3
7. Samsung Tab Pro 8.4
8. Samsung Note 5
9. Xiaomi 16000mAh powerbank
10. Huawei Nexus 6P (Coming Soon)
For 7, 8 & 9 will depends on my the other half permission.
For every device, once it hits below 5% battery level. It will take in the most power needed. Once it hits below 5% i will plug the device with every multi port chargers and measure it using the Drok Mini USB doctor that is capable to measure anything from 5v-12v and 0.01A- 2.4A.
The total power taken by the device will be shown in the "P" stated on the Drok display. Which is actually P=I*V. This will give the most acurate power drawn from the multi port.
The results will be posted in screenshots here, and eventually tabulate into graphs or excel form.
Also for Quick Charge 2.0 aka Adaptive charging for Samsung terms enabled devices such as Samsung S6 Edge, Aukey 15000mAh powerbank and note 5, there will be a seperated column on collected results.
So lets take off the first device.
Samsung Galaxy S6 Edge
For the start, the Aukey took a lead with a total of 8.891W, followed by a tiny difference from Thecoopidea which managed to output a total of 8.857W, followed by Anker 8.364W, and the last would be Choetech at 7.3W, BUT however, since the phone has Samsung Adaptive Charging capabilities, both the Choetech QC 2.0 and the Aukey QC 2.0 will lead in fast charging. Results shown that the Aukey took the crown at 14.43W, and the runner up goes to Choetech which doesn't look shabby at 14.3W.
Anker
Thecoopidea
Choetech
Choetech QC 2.0
Aukey
Project Energy
Anker 6 Ports 60w
Thecoopidea
Testing Analogy
1. Samsung S6 Edge
2. Xiaomi mi4i
3. Iphone 6 Plus
4. Ipad Mini 4
6. Samsung Note 3
8. Samsung Note 5
Anker
Thecoopidea
Choetech
Choetech QC 2.0
Aukey
