adrianlee
- Apr 28, 2001
PC Power & Cooling Silencer Mk III 850W Power Supply Review
Enermax Triathlor FC 650W Power Supply Review
Corsair AX and AXi Series Power Supplies Review: Small Letter Big Difference?
PC Power & Cooling Silencer Mk III 850W ReviewNot too long ago, I took a look at a new PC Power and Cooling unit that turned out to be just plain awesome: the Silencer Mark III 1200 watt unit. Today, I'm looking at the little brother of that unit, the 850 watt model. We'll find out today if this 80 Plus Gold unit can match up to the high standards set by the flagship of the line.
Enermax Triathlor FC 650W ReviewRecently, we took a peek at a new case from Enermax called the Giant Ostrog. Today, we're looking at an Enermax power supply you may choose to use inside that case, the Triathlor FC 650W. This is a budget minded 650 watter that still brings such features as semi-modularity and 80 Plus Bronze certification to those of us who cannot afford the better and more expensive models. Let's see what it's like, shall we?
Corsair AX and AXi Series Power Supplies Review: Small Letter Big Difference? - X-bit labsToday we are going to check out two pairs of “Platinum” power supply units with capacities of 760 and 860 watts, which belong to two different series: AX and AXi. Which one should be a preference for those who are looking for the most efficient power source for their systems?
