Do you have the NAS-cessary Connections? Get in on our discussion and win prizes!
harky
The DS216J has up to 16TB of raw capacity, allowing you to store all your data in one place for easy access anytime, anywhere.
roxas93
The DS216j has up to 16TB of raw capacity, allowing you to store all your data in one place for easy access anytime, anywhere.
WhiteHunter
mosmos
High Honorary Member
mosmos
Synology DS216j specifications seems to be too good to be true for such as small unit with prices below $300 in local qoo10 website.
But seems like without HDMI connection to allow 4K transcoding capability.
Local connections Front: 1 x USB 3, Rear: 2 x USB 3, 2 x LAN, eSATA
Network connections 2 x Gigabit Ethernet
Storage: Up to 2 x 8TB hard disk
Cables: 1.5m Cat 5 Ethernet
Cooling: 1 x 60mm fan
Feature: FTP server, Print, webserver, independent download (via HTTP, FTP and BitTorrent), iTunes and UPnP media sever, DLNA, storage server, photo server, video server, external USB hard disk support, One touch copy button, surveillance server, Cloud server.
Dimensions: 102mm x 225mm x 169mm
mosmos
no 2GB ram, really cannot for me. Dual Core 1.2GHz is decent though. more often than not, 1 could easily exhausted the RAM but never the CPU.
The basic models are good to rival competitors offering, but at that price point as well as the specs, i would've gone for D-Link NAS instead.
if Synology DS216j NAS has 2GB ram, might be able to allow 4K transcoding capability~ :s22:
since there are 16TB of raw capacity, able function as FTP server, Print, webserver, independent download, iTunes and UPnP media sever, DLNA, storage server, photo server, video server, external USB hard disk support, One touch copy button, surveillance server, Cloud server.
Elijahonli
mosmos
This entry level NAS certainly cut alot of corners from DS216+. :(
Yes, I though Synology DS216j was an updated version DS216+ with same DSM 6.0, data protection encrytion, Btrfs file system and 4K transcoding capability.
since Synology DS216j can install up to 16TB of raw capacity, with the kind of basic NAS connections, mainly for backup storage, should have allow 4 HDD slots to increase up to 32TB of raw capacity.
Elijahonli
It would be great if Synology can include in Web server as well...
wadsad
The DS216J has up to 16TB of raw capacity, allowing you to store all your data in one place for easy access anytime, anywhere. (24 words)
batniss
Actually there is a Web Station in-built. You can use the inbuilt web station to host webpages. It supports PHP as well.
Just remember that port forwarding and port 80 is required for such process otherwise your users or customers have to load the page url together with a funny port eg <Elijahonli.synology.com:52222> instead of <Elijahonli.synology.com>
you can get more info here: https://www.synology.com/en-global/...ication/How_to_host_a_website_on_Synology_NAS
mosmos
I am missing 5 points guess the answer was not correct?
kero89
Bro your specs looks a bit wrong for the synology ds216j. Cross reference correctly?
viktOzzz
New Synology question. Answer below:
mosmos
sorry, I may have reference the wrong specs from the website for DS216j
Link: http://scalewireless.ee/wp-content/uploads/2012/07/Synology_DS216j_Data_Sheet_enu.pdf
the below specs maybe for another synology model
Elijahonli
wah this is really nice
