LG V10 - One hell of a phone!
Oinkize
Hi All,
What's the price for a v10 spare battery now locally?
My original battery kaput!
Is it cheaper on Qoo than local shop?
Taobao ones can buy?
What happened to your original battery?
racer46maut
There can be miracles, when you believe...
Let's wait till the product is available in sg and see...
Edit: read that the China variant with global ROM does support 4g/3g standby. Now we need to see if India variant supports the same...
Thank you for sharing this information...
Yes. Got 1 bro here able to do so in mi5.
This was his screenshot... But of course, need a local mi5 to reconfirm (when officially launched here).
Sent from LGE LG-H961N using GAGT
Didn't understand why nobody believed me when I said that our dual sim supports 4G/3G..
Need to be more convincing next time...:s13:
19dino
When charging it shows 100%, removed plug 5mins or less show less than 5%.
I was watching runningman once while leaving it plugged in... Guess that killed the batt as this phone can get quite hot with heavy usuage like when gaming.
Oinkize
Wow. That's serious...
Oinkize
Yes but this Mi5 was already widely discussed in the Mi5 and other threads in HWZ. Complete with pictures.
That's the thing lor.
Not all visits the threads which you have mentioned.
Thank you for sharing this new hope to us...
TheOutsider
Dual 4/3G isn't just a software trick. Else those Custom ROM maker for sure bake it in long long time ago.
It involves hardware too. Can do some Google then you know what I mean.
racer46maut
OUR hardware supports it, just that you need to enable it through the hidden menu [type in USSD Code] select Field Test, Modem Settings, LTE Band Selection;)
Been doing this to both on my G3 and G4. But if you are using the HK version you should get 4G/3G automaticlly if you are in HK and china. If you are in SG you need to know your service provider bands to enable the 2nd SIM 3G settings.
Oinkize
I tried pressing 277634#*# and there is no response. Mine is a sg set with hk/global set.
I hope to turn on 3g for my 2nd sim. Can advise?
hellojeffo
So, after entering the Hidden Menu,
I went to Field Test > Modem Settings > Network Mode
THere's a long list of bands that the phone supports, and you can click on each to test. It will show SUCCESS/FAIL
Below are the SUCCESS selections for both sims
SIM 1 (Singtel), WCDMA 850, 900, 1900, 2100 and GSM 850, 900, 1800, 1900
SIM 2 (Maxis), only GSM 850, 900, 1800, 1900
Now, if I switched SIM 1 to any of the GSM bands, the SIM 2 became able to select the WCDMA bands...
Which proves that SIM1/SIM2 can only exist in a (4G or 3G) / 2G combination or 2G / (4G or 3G)
FYI, WCDMA are the 3G, 3.5G (HSDPA), 3.75G (HSPA+) network types; and
GSM are the 2G network types
LTE is LTE ...
racer46maut
*#546368#*961#
but I don't see how to turn on 3g for 2nd sim
LTE is LTE ...
go to=>Hidden Menu=>Field Test=>Modem Settings=>Network Mode
You should see what are your SIM 1 & SIM 2 factory enabled modem protocols. In order for your 4G/3G to work you first have to knw your service provider 3G network band(s).
Oinkize
Tried clicking all bands for sim 2 and all failed except what hellojeffo has mentioned. Only 2g...
