New Gaming Rig SHARE IDEA THANKS!
ZrE0_Cha0s
Zreo,
i checked this board cannot fit in 950 pro sia. 80MM this 1 only can put 60mm
damn then forget about it. didnt expect it can only put 60mm, cos local im not sure who have sell any other better m.2 ssd with 60mm... :(
ZrE0_Cha0s
If not i got to change my MOBO to ASRock Z170 Gaming-ITX/ac
asrock im not sure of their length as well, maybe u can consider asus z170i pro gaming?
or GA-Z170N-WIFI (rev. 1.0)
both can support 80mm
runforyourlife
Moderator
Moderator
bro what CPU cooler u using? way to go man, we have same case!!! :D :D i also building one and have a thread also :s22:
Pyre
MOBO : Z170I GAMING PRO AC
Processor : i5-6500
GFX : MSI GTX 1070 GAMING X
RAM : CORSAIR VENGEANCE LED 8GB x 2
Storage : SAMSUNG 850 EVO 250 X 2 ( RAID 0 )
Casing : Carbide Series Air 240 Arctic White
PSU : PLEASE HELP ON THIS.
what monitor u planning to use.
what resolution u planning to play at.
what games u plan to play.
Tsuchimi
144HZ monitor.
FPS / MMORPG.
for all this im still know what to do. Just that first time making mini ITX
and new skylake i havent really go read up.
Somemore Mini ITX MOBO, i prefer MSI, but doesnt support 2280 m.2 which is certainly kinda of disappointed.
Pyre
144HZ monitor.
FPS / MMORPG.
I think u need to do abit more research. 144Hz there are plenty of monitors, but my question was RESOLUTION not frequency :)
if u plan to play at 1440 or 4K, then you may want to make sure your monitor supports the right display port version AND the right display port cable etc. otherwise you get all the high-end gear but your monitor and display cable is the bottleneck.
otherwise enjoy the new PC :)
Tsuchimi
Hahaha thanks. Monitor wise more or less settled, wanna try out something different. HKC X3 some MIC brand. If not that good then i switching back to BenQ but getting the 27 inch model.
runforyourlife
Moderator
Moderator
Share your com specs too. Lai lai!
tata:spin:
Purchased
Corsair Air 240 - 125
Superflower 650W Gold - 135 (Collecting on Sat/Sun)
Corsair Vengeance 16GB (2x8G) DDR4 BLACK - 110.50
Samsung Evo SSD 250GB - $118.99 (Free 8GB thumbdrive somemore)
LITEON DVD RW 8X SLIM Black - 27.29
Windows software - Special price :o
ID-Cooling Frostflow 240L CPU AIO - White Ring, White LED - 92.65
Pending Purchase
i6500 gigabyte b150m-d3h - 417 (tradepac) or quote from Fortran
Gigabyte 1070 g1 gaming - 768 (pct) or quote from Fortran
WD 1T Blue - 76 (pct) or quote from Fortran
Pending: $1261
