[Official] Geforce GTX 1080/GTX 1070 discussion
ZrE0_Cha0s
Powercolor devil, Asus and MSI iirc they are making long GPU. Not sure for gigabytes and XFX.
freakerknoid
1 month plus after release still there is not enough stock. Hype up so much but no stock to sell.....sad
ragnarok95
Senior Moderator
Senior Moderator
Thats a problem with big and long gpus. Including those short but fat gpus. Lol
At least RX480 and Fury X, Nano wont sag lol.
Vanilla design like the AMD HD69XX, R390, R290, Nvidia 6/7/10, titan etc won't sag, with or without backplate cos the shroud are screw to all 4 corners of the PCB. :D
That's why i like stock design. :o
timpeh82
just got back from sim lin square. no new stock of 1080. next tues or wed got stock
leadtak brand. reliable??
harharhar
They are nvidia OEM which usually makes the workstation Quardo cards. May not be so well known among consumers (no marketing like asus/msi). But they are ok!
artyboy
Strange, I was just in SLS yesterday and I saw lots of Zotac, Palit and even MSI GTX 1080s...
marsbarsz
Hi guys, it's my first time OC-ing and would like to know if I did it correctly? I'll attach the benchmarks results below and I'm using the ASUS strix 1070 on a 2560x1440p monitor
Here's my settings on the MSI Afterburner
Here's the diagnostics on GPU-Z
Here's the benchmarks before I did any OC (i'm using Win10 Pro, not sure why it indicates Win8)
Here's the benchmarks after I did the OC-ing
How I did oc was just to slowly play around with the Core and Memory clock by 25 incrementals and then go back to Unigine full screen to check for any artifacts or flickering. Once there flickering and artifacts are gone, I just saved the MSI afterburner settings. Are there any steps I missed out?
I dont know whether this information will be useful but I am currently just using only one 200mm casing fan in the front of the casing but I am planning to buy another casing fan to put at the rear soon
royfrosty
Your card is indeed very hot struggling for air. You will need a better way to bring air into your chassis.
marsbarsz
Thanks! Yeah that's why I am planning to get an extra fan to place at the rear of my casing, I hope it will help?
Also, can I confirm if the settings are okay and my steps for OC-ing were correct? I'm afraid I do wrong settings that will spoil the GPU.
