Anyone know any good guide on how to play this game..
I am kind of confuse ...i dont know how to recruit more troops..
Play Hero mode first. It is kind of like a tutorial.
Hope this helps.![]()
Strange that Koei don't mess with NA series. The game is always about strategy.
I stuck at hero mode where sun jian need to fight liu biao... always lose, his army so big how to win![]()
Try hiring more generals, recruit more troops, and train the troops.![]()
Aiyo this game is really quite nice, why so many bash....
1. recruiting general. If you want your zhu gong to recruit, u need manually go to know that person first (if you dont know him, he wont talk to u) by asking ppl to intro you or hold party (need wine to target specific ppl, know this from my friend). Dont bother lah, just get your ka kai to recruit. I only use my zhu gong to find ppl nia.
2. After you conquer the city, you can choose who to shift. After shifting, once you jie san the troop, they will go to that city. This game does not allow you to shift troops. Only resource and general.
3. The troops at your city is based on your population and your ming xin. In order to reach the max (100k troops), you need to have max ming xin + dont use that city for war because if your troops die, your population go down too.
4. You can auto refill your food once you past the city (at the settings) and also ask your general to pick the addon to be build.
5. Sometime if you fight in 1 city and cant conquer it because the reinforcement keep coming in, cut off the path or go on multiple invasion.
6. The tai shuo and du du is VERY IMPORTANT. Tai shuo can help you to develop the city much better but need at least 5 pin. Dudu is best - just assign him to every city. You can set tai shuo for the city your zhu gong is in also.
7. Always set the direction for your force. They will work towards it (if you have dudu or tai shuo)
8. If your city is falling, u can trf both the resource and general out.
9. Tong Meng IS VERY IMPORTANT. you dont want to have all the force come after you when you are too strong.
Hope all this helpAnything can ping me.
Hi, I'd like to ask, what does weapon proficiency and fealty do? It doesn't seem like they are affecting anything as far as I can tell. Also, everytime it says your city can build some new buildings, is it auto built? I cant find where to go build stuff..
No idea about the weapon proficiency and fealty do. To be honest, i don't go into battle anymore LOL
For the building, there is a setting to auto build it. You can choose to manually select. I think the default is manual. A screen will auto pop up with 4 options and you can select 1 of them.
You can win without doing battle?
I never get any popup, I guess its auto then?
Not that true, the key is to hold out the attack.U must ally with others. I think most impt to win the game liao. The alliance against you very hard to win against if you dont ally the strong. Basically just ally him, surround him so he cant grow and you should be able to win
Check your settings
Not sure if the AI is stupid. After a few waves, the weaker ones will stop sending. You can send some troops to capture these cities
Sent from Kanto using GAGT
Yuan Shao is troop many but not many powerful generals.Of course the weak alliance is ok but i encounter 5 force including yuan shao coming after me from all direction because i didnt ally enough. It mostly happen when u get too strong too fast.
Any expert kindly correct me if I am wrong:
- Higher weapon proficiency allows stronger troop type, i.e. Light Horse > Heavy Horse > Elite Horse
- Higher fealty allows you to recruit more troop
