Xiaomi Mi 5s/5s Plus
beyonder
Expansys is selling the Mi 5s/plus claiming it runs Miui 8 Global ROM 8.010.0.0(MAGCNDH). But I didn't see Miui Forum mentioned that global rom for Mi 5s is available. Is Expansys giving the wrong info?
kyleongwl
I hope Global rom available soon...
Yes the China with sideload play store seem fine..(but for gaming...status, acheivement etc...at time messy or not supported)
jackycar
That sounds like custom. Rom that cannot get updates. Mine is China ROM 8.0.7 MBGCNDH works perfect leh
beyonder
Just found out that 8.0.10.0.MAGCNDH is actually a China Stable ROM.
http://en.miui.com/forum.php?mod=viewthread&tid=370651&extra=page%3D1&mobile=2
woodlander
ever since note7 die... i still wonder what phone to buy. Thinking to buy a temporary phone before note8 come.....
should mi5s worth?
the dual sim is 4g/3g or 4g/2g only?
if buy mi5s, from lazada or qoo10?
anyone know any seller are reliable?
garychengjw
should mi5s worth?
Has already reported. It's 4+3g.
Depends which seller offered the best deal. Can't really recommend which is the best. :)
Sent from Motorola MOTO Z Play (XT1635-02) using GAGT
woodlander
This is how lazy i am.... no exploring this tread early..... not annoying the $35 discount... so sad
walterteoh
Hi Bro,
May I know the China Rom 8.0.7 for Mi5S plus got dual apps feature? I knew MiMax got this feature in Rom 8.0.x,. Need to confirm this before order.
Thanks
Walter
freezerz
Can check since this is only China ROM, can change the interface to English language? Or stuck with Chinese only?
Also check can the NFC use for Android Pay?
Now debating between this or LG V20... this wins as so much cheaper, but not sure of functionality.
amazingone
The China ROM has three language choices, including:
Chinese (Simplified),
Chinese (Traditional), and
English.
Android Pay should be able to work, but I'm not too sure of compatibility. Maybe those who have the 5s Plus may want to comment on this. :)
Sent from Sumire using GAGT
freezerz
English.
Thanks. That resolves the language.
Read the specs is "Full feature NFC" but that's probably open to interpretation, not sure of details. Anyone use Android Pay successfully on this phone?
bbcccc
one day rched le
Sent from Orion using GAGT
