Huawei P9 - Change the way you see the world. #OO
foosoomin
Huawei is not solving the current problem, it create more problem instead.
I found a lot of complains in it's phone usage, especially the wifi compatible problem
foosoomin
caterham,
i write it simple.
Huawei should use wifi chips that is compatible with older wifi routers, so that users can use Wifi without any problems
foosoomin
felt very happy with my Sony Xperia XZ, after giving up my P9.
Shiok man Sony............
Though Sony android operating system may not be better than Huawei, at least Sony wifi chipset support older router settings.
User will NEVER have to worry about Wifi not compatible problem
foosoomin
peasantbeing,
switch to other brand, much better.....you have much lesser worries
garychengjw
Stop your "wifi not compatible". It's more like your router having issue. Getting annoyed... (Not only post here...)
Having say that, I've used p9 and mate9. Connecting wifi have no issue.
It's either your previous huawei phone is lemon set or your connectivity device having issue.
Enjoy your xz.... Cheers.
Sent from #HTC10 using GAGT
Bryson
I agree. Technology advances and sometimes we just have to move forward. My set has no problem connecting to my old d link router before changing too.
qyc_91
Yup, everyone still ending up buying macbook pro this year despite all the ports are changed. Huawei just keeping itself update to technology
batboyz
"Everyone"? Very bold statement... I for one certainly am not in that "everyone".
gbjack
The Swype keyboard in Huawei is a piece of sh-it, and so counter productive in typing.Fortunately, Google Keyboard comes to the rescue.
qyc_91
lol good for you to be different. *clap for you*
while the rest should get what I mean by everyone and not emphasize on the word I used. :s13::s13::s13:
qyc_91
I ended up using Google Keyboard too. just got used to it across most device I used. though I still prefer LG keyboard if given a choice
batboyz
Nah, no need your clap, thanks for the clap though.
Oh, obviously everyone is different, if everyone is the same, then it is very boring, hence the argument/opinion.
Not emphasising on the word you used, simply mentioning the word that you used. Everyone was certainly not accurate based on the context given. :s13:
gbjack
I am adapting well to the UI overlay. It's not like what many reviewers said. I prefer it over Samsung interface.
tazzi80
Actually I quite like the UI also. Takes some time to get used to it but after a while its actually ok.
