Xiaomi Mi Max 2 - The new BIG gets even better!
Yuripa
I've got 2 locks on my screen. Quick ball on the middle left (sorry unable to screenshot) and lock widget on the bottom right.
Unfortunately I've set fingerlock so doubletap to unlock is impossible for me. Since I'll still have to unlock it via password after wake to doubletap.
Sent from Nokia 8800 without using GAGT
1c3_5n0w
Sian... How come mm1 and mm2 the charging cable different..........
Every manufacturer of Android devices is moving towards USB Type C. Adapters and cables are really cheap on AliExpress anyways.
imacbie
Every manufacturer of Android devices are moving towards USB Type C. Adapters and cables are really cheap on AliExpress anyways.
cheap but might not support certain type of charging pattern if voltage it can carry is not enough.
storm913
You can try activating 1 handed mode by swiping thru the 3 capacitive buttons.
Sent from Xiaomi MI MAX 2 using GAGT
In the settings, there is key and gesture shortcut to set go to sleep with long press of one of the capacitive button. Also there is 1x1 size lock widget that place anywhere on the home screen or in the dock.
You can add a lock screen shortcut to the Quick Ball option, alternatively is to use a third party launcher that have the 'double tap to lock' features, such as the Arrow Launcher. Not sure why XiaoMi implemented the double tap to wake but not double tap to lock.
Wow, thanks, I will try these out and see which I will like better. Will be looking to buy the ring thingy so i can use the phone one handed when necessary :s13:
1c3_5n0w
er ok just saying only? if u scared then buy more expensive one la.
USB C have faster data rate and higher current specs.
Whats wrong with USB c that u don't like it?
its also reversible haha really convenient when i plug in my phone at night. first world problems.
imacbie
well yeah, just thought i'd say tho i doubt many pepole care. :)
Lil_d3viLz
Just cracked my mi max 2 screen.
Under warranty but i doubt it covers cracked screen.
Any shop doing a cheap repair?
testerjp
The big screen think makes it really easy to crack. :o
Never put glass screen protector?
Joe Maya
Ugh why my mi max 2 keep on restarting when I listening to music? Helppp
Dovahkiinskyrim
Those who purchase Xiaomi phones on qoo or Lazada. Those export set with warranty is "ship back to china"??
Shipping cost u have to bear right?
+ waiting time 1 month?
Like that worth it meh?
