booster888
- May 18, 2012
You kena Guanyu S3 lah... lol...
Coins burn fast after update, from 20m now dropped to 14m![]()
GY 3rd skill dmg low right? But can burn...
bro u power !!During the 3 X Exp hot time, use the 2 X XP scrolls.
You will have 4600exp X 5 = 23000 XP per ticket use at 9-10E.
Officer 4* Level 0 to 40 needs 77100 XP,
You put 3 X 4* 0 Level fodders, Raid Tickets 3 times will go to 69000 XP. Lv38+
Repeat until all your 4* fodders all become late Lv38+, still during the 5X XP time, use a Leader Officer to play once 8-5H or 8-9H to get 1700XP X 5 = 8500XP,
total: 69000 + 8500 = 77500
to complete the 4* fodders to 40Level.
Basically is 1 ticket per Fodder needed. 3 tickets to up 3 fodders.
I made more than 40+ 4* Level 0 to Level 40 during that 1 hour.
Wah lao! U robbing a poor man!![]()
Looking with envy at Booster's setup of GY ZF LB, I went to count the Nat5* gold heroes I have. I realized that after playing for about 30 weeks (started since mid-June 2017), I have collected 62 pcs of Nat 5* Gold heroes. Is it considered lucky or suay? Care to share yours in this Kaypoh survey?
[Quite easy to calculate (6/6 = 7pcs, 5/6 = 6,.. Can include spare/untrained heroes and Red* Scroll)]
No. of Nat 5* Gold pcs: 62
6/6 Nat 5* Gold: 2 only
Start date: June 2017
bro u power !!
Paiseh Paiseh...I think any Bros here already cleared 9-10E can use this method to mass produce 5* fodders.
And i also calculated the needs for 5* to Level 0 to Level 50.
for 5* Fodders: Level 0 to Level 50 needs 225,000 XP
One Run at 9-10E with X3+X2 XP is 4,600 X 5 = 23,000 XP.
So need 9.78 (10) tickets to make 3 X 5* Fodders from level 0 to level 50.
Or you can use 9 tickets make them to Level 49, 207,000XP, the balance 18,000 grind in Level 9-2E or 9-8-E 2 times should be enough.
Make 6* fodders for slots opening.
Hey guys which stat do you prefer on your costume
Artemis Kappa - 50% chance to freeze on debuff
or
Zeus Gamma - immune to freeze/stun 10s if dmg >5%??
ideally how many raid ticket we need to have. to take advantage of this hot time ?
currently only hv 55
i just noticed i havent try 9-10e. not sure if my xhd can handle.
anyone can share tips for 9-10e ? which part i shud build my musou
Lol... relax lah... this is arena... will never touch a fellow warrior’s mine...![]()
