Need help in computer suddenly shut down..
Mincedmeat
hi guys, so my computer suddenly shut down last night while i was using halfway.. and i can't turn it back on.
- GPU light is on
- PSU, have tested the paper clip method + multimeter check on all the pins, all are working fine.
- Have use individual Ram to power up, still no go.
Does it narrow down to just motherboard and cpu ?
shadow84
Try remove CMOS battery for 30s, put back in and try power on.
jtjt00
GPU >>> Motherboard >>> PSU
Bring rig to Nigel if you don't have spare to test these parts.
You can find his contact at Facebook.
ZrE0_Cha0s
does your mobo have any error code display? if have search the manual for the error code.
could be mobo gg.
shadow84
Remove cpu and check for any bent pins on the mobo cpu socket. If not, rma your mobo.
Also, have you tried removing gpu and using on board igpu to check for display??
Mincedmeat
I did not tried removing gpu and using on board gpu as the system can't bootup at all. Will try it later on.
Mincedmeat
got beep sound, when it couldn't start?
I've found out the problem! Turns out it's my GPU
Tried taking it out and powering up, everything back to normal without the GPU, now the problem is to find a new GPU...
raysusan
Happy that you found the problem
But gpu price....
undead102
Stocks is got stock but it depends on whether you want to pay the exorbitantly high prices for a new GPU now. If not can consider getting lower end gpus prices for them are still ok. Gtx 1060 and above very expensive.
