Xiaomi Mi Max 2 - The new BIG gets even better!
Yuripa
Can I ask a noob question on max 2 ?
If I use a SIM extender, can I do voice calls and data internet surfing on both SIM cards on this phone ?
Or does it have to be either one SIM active on the phone at any one time ?
Thank you in advance
I'm unsure whats a Sim Extender.
But its a dual sim mobile phone, there is a hybrid dual sim card slot with 1 of the slots acting as a micro sd card slot.
You are allowed to chose to make calls or use data separately.
Calls - Choose sim 1 or sim 2 (no option to choose both sims)
Data - Choose sim 1 or sim 2 (no option to choose both sims)
lionelfoo
Just got my hands on mi max 2. any idea how do i get miui 10 global rom on my phone?
Many thanks!
windwaver
bro. whats so good about lineage rom?
Waiting 72 hours to unlock my new Max 2 bought at $236.90 :D.
It's the most stable and bloat free ROM for Mi Max 2 (Lineage). Android Oreo is also announced so it's a matter of time before it's stable enough to flash.
I just can't get my head around to use MIUI because it's just bloated.
pokipoki08
Asus Zenfone 5 Max will not be a typical mid-range device but an upper mid-ranger with great performance. If the price remains affordable and the battery as big as the ones on its predecessors, this device may become a best-buy in its range.
Source
Snapdragon 660
If the battery is 5000mAh, TruSignal & Aqstic audio is good. Good contender over Mi Max 2, heck over Mi Max 3 even. Smaller screen too.
used lineage and didn't like it as it drained battery. switched back to miui. not sure about now.
windwaver
Latest MIUI is pretty good. It's basically down to which interface you prefer and the level of customization available.
It's probably some wakelocks that causes the battery drain. Wakelocks can be monitored and reduced. Flashing a good kernel can help with massive battery drain.
Think I saw some folks mentioned 17hr to 18hr SOT on the Max 2. There are some extreme numbers but it's usually for people that are hardcore.
imacbie
unfortunately.... all codes are still hole up with xiaomi now.
there is no 3rd party kernels available now. waiting forever.. zzz
snipfer
Side tracked a bit
Which music player is good? Xiaomi one cmi
Sent from Xiaomi MI MAX 2 using GAGT
