Xiaomi Mi Max 3 - Come in!
carboy00
at least a few months later :p go check on how long did redmi 5 and redmi note 5 came out in SG when china have already launch them.
Not to mention Mi MIX 2S... How many months since launch in China and other markets liao...
Sent from Xiaomi Redmi 5 using GAGT
ZrE0_Cha0s
oh ya, that one even they said mid july will have...dunno true or not.
rathalos
Mi max 3 display component..
2018-New-For-Xiaomi-Mi-Max-3-LCD-Display-Touch-Screen-Digitizer-7inches-Mi-Max3-MI.jpg_640x640q90.jpg_.webp
ZrE0_Cha0s
Good! No bloody Notch! :s13::s8:
seems like have lei, i mean if u see the top of the center part of the 1st pic, even though its not clear but i believe that it might have.
even if dun have most likely will be like note 5 screen.
kelvinti
To me! It looks like the normal 2 holes and the speaker under the glass! Hopefully I'm right!:s22:
ZrE0_Cha0s
Well about the back of the internal seems like could be hint of wireless charging/NFC of such. (It does seems similar to a few phones with such internal on the back.
kelvinti
Got pro and non Pro models... So, could be some added features for pro model only..?
kelvinti
Pro non pro difference is the SOC/ram/ storage capacity only.. the rest are exactly the same..
I see. :). Wireless charging is more likely than NFC as Mi Max is still categorized as a media phone.
rathalos
The rumours said there's wireless charging, but doesn't seem to be implemented here.. cos usually the induction coil will be embedded into the back cover for efficiency..
ZrE0_Cha0s
well its just the cover for the back and no much internal flat wires or any flat stuff is connecting it like the front for the display. so hopefully when they official release it will we know more if it does comes with it.
rathalos
Wow! Nice. :)
I wonder... How curvy is the side screen? I think it will not be a flat screen, right?
From what I observe.. the screen is flat.. it's probably the chassis is curved on the sides for better grip..
