Xiaomi Mi Max 3 - Come in!
kelvinti
The max 3 getting bigger and bigger.. bigger size, bigger screen, bigger battery:eek:
Really must see how much bigger the dimension than max 1 and 2.
I'm already so used to carry the size of max 1.. Not an issue for me days in, days out.
garychengjw
HOUMAI WHITE!
got mix2s white aura..+1
Sent from Xiaomi Mi 8 SE #BrightRED - The compact Mi Flagship using GAGT
1982-1994
does not look like 6.9"
Sent from Xiaomi MI MAX 2 using GAGT
Nakedtoes
max 3: 176.2 x 87.4 x 8 mm (6.94 x 3.44 x 0.31 in) 221 g (7.80 oz)
max 2: 174.1 x 88.7 x 7.6 mm (6.85 x 3.49 x 0.30 in) 211 g (7.44 oz)
max 1: 173.1 x 88.3 x 7.5 mm (6.81 x 3.48 x 0.30 in) 203g (7.16 oz)
kyiori
MiMax is getting heavier for every new version. My pants gonna feel very heavy. Lol
Nakedtoes
yeah lor... i dun think it has the same camera spec as note 5.. but if it is using SD710 and the hugh battery then it is tempting
carboy00
Really hoping the rumoured Pro version with SD 710 turns out to be true. That will be great.
ZrE0_Cha0s
Well what do u guys expect?? If u wanna a bigger batt den weight is definitely increase and also with bigger screen as well.
1982-1994
8mm thick is fine as long as battery is huge.
unlike latest Sony xperia, like 10mm thick but battery not big enough.
Dorkable
Mi Max dimensions get closer to Mi Pad every year =:p
Hope MM3 has at least same front and back cameras as Note 5 :D
garychengjw
Mipad 4 looks very Mimax3 but less calling function lol
kelvinti
I'm more concerned about the 3mm increase in height! All my current pants pocket might not be deep enough...:s8:
Probably need to alter to a deeper pocket! :s11:
