I'm wondering is it possible to get it within another month's time.
Depends. Maybe possbile. But anyway i still think that depends on how fast they can make the phone.
Let's see who will be the 1st person to show his Mi Max 3 here....
Available from tomorrow onwards in China, means very soon will have export sets in Singapore.it is all about the sauce now.., anyway china release alr?
https://i.imgur.com/AwKlMLr.jpg
Just wondering about Google apps support.. hmm.. I heavily use Google apps..
If only storage upgrade like the mi max 2, I'll get the lowest config because microSD card is much cheaper but we can't upgrade ram like storage so I'll usually go for the higher end model.for phone like that dont need save money just buy highest configuration, this is what i learnt during mi max 1.. this phone will last you.
Not much issues for me since I'm using otg thumbdrive.If only storage upgrade like the mi max 2, I'll get the lowest config because microSD card is much cheaper but we can't upgrade ram like storage so I'll usually go for the higher end model.
Who is snatching is tml???
Sent from HUAWEI MATE 10 using GAGT
