garychengjw
- Jul 18, 2010
SssssmtlI alone at Nex thread sia... Sianz
Sent from Vivo NEX S 256GB using GAGT
Sent from OnePlus 6 In Red
I try to drop by there liao...and if no one ask qn..i cant comment mah
Yes...that why need to install a launcher first...then remove oppo launcher through adb.Just went to molest the find X at nex. Sales girl tell me can load custom launcher but official reply from Facebook say cannot. I load nova launcher. After 2 tries then succeed but once press home button , immediately go back.
Go default apps under settings cannot see any option for launchers
Unless they fix this I no Bai Liao. Lol
Hand feel and size very much like S9+
I had both...and yes, vivo do looks better (bezel top is small) and better sound (dual).
After watching this, I’m having second and third thoughts about getting the Find X
However, i notice myself, like many, will use earphone so...dual speaker is rather useless.
On top of it, it weight and thickness looks heavy...
Oppo have amoled screen (color is better) and design is sleek
For me, the camera should not be the deciding factor (novelty will wears out)
Both units is for the screen (90% screen to body)...no notch...no button
I noticed that u uses ipx.
Dont believe the UI look alike. Today, ipx has the better gesture (maybe xiaomi or oneplus cpuld come near)
I just bought the Oppo Find X. now at phone shop waiting for them apply the screen protector. now under UV light to cure the adhesive.
Wow... they also using the UV tech??? i just installed myself... starting swee swee.. now corner like somehow not sticky... tonight i go home n try shine uv at it again... see got help anot.
Me uses pin now...the camera is fast..just worry intensive use will break it.The handphone shop I went to had the screen protector with the liquid uv adhesive. now still ok. have to observe a few days see how first. Im a long time Huawei and Apple user. The oppo full screen is so beautiful with no notch. I use normal pin entry for my. phone. dun wanna wear out the camera motors
U got an export set?
So far Im loving the full screen. Its beautiful. If only it has a fingerprint sensor that makes it easier to unlock the phone
Dont worry la.. just use facial unlock la... if not this feature is going to be a gimmick...
that slider faulty is ur least worry when u dropped it.
Which shop did u go for the tempered glass? How much is the damage?I just bought the Oppo Find X. now at phone shop waiting for them apply the screen protector. now under UV light to cure the adhesive.
Sent from Samsung SM-N950F using GAGT
I bought my phone at red white mobile and they applied the tempered glass for me. $30.
Porsche Design Huawei Mate RS
