Gametaku
- Sep 24, 2013
aliexpress, total around sgd $700
much more straight forward than taobao/ezbuy
which seller did u get it from?
Hi all,
Can i ask some question? what is the total damage for the 6/128GB to ship to SG if i buy it from taobao? (apologies.. i see pieces of info but i cant really sum it up)
if i got it shipped from china... what kind of steps i should do inorder to make it workable in SG?
appreciate it for the help... thanks you.
I finally made my purchase from this seller:
https://www.aliexpress.com/item/Hua...022.html?spm=a2g0s.9042311.0.0.37934c4drrLnVX
$693.35 for 6/128gb. Can use some seller coupons for further discount.
3199 RMB + Alipay fee + Credit Card charges + Forwarder charges + GST.
Total should not exceed SGD$700-750. The main variable part is what the forwarder charges you. The rest is very standard. Alipay and CC charge is very minor.
If buying on Taobao, I strongly suggest you go with the Honor Official Tmall Store (荣耀官方旗舰店). They are very fast and no gimmicks.
You don't need to do anything to the phone. It works fine. Just install Play Store from the Huawei App store. You can also remove most of the pre-installed apps and use another launcher if you prefer.
If you want to include an SP, this one is very high quality
https://detail.tmall.com/item.htm?id=566495475912&spm=a1z09.2.0.0.5f7e2e8do3dEH1&_u=j1p1f55b9578
If you want some other case, the official case is out
https://detail.tmall.com/item.htm?id=574646141910&spm=a1z09.2.0.0.5f7e2e8do3dEH1&_u=j1p1f55b4d97
People dun work on weekend one lah. I already told u my time frame, expect around the same. And check if they msg u.Hooted another set from JKteam after kennyboy recommendation. Ordered since weekend but no movement till now. Order stuffs from other sellers around the same time already shipped![]()
Any bros playing Walking Dead Our World on this phone? Is the GPS tracking accurate on CN rom?
Bro, whats your order status showing? I oso ordered last weekend and my status is showing Awaiting Shipment....
But i use AliExpress Standard Shipping though...
How to check if turbo is activated?
Sent from HUAWEI RVL-AL09 using GAGT
