Honor Note 10 (6.95 inch AMOLED)
ccmheoa
Somehow this phone is a lot smoother than honor play, even though same CPU
Turbo can be enabled even on normal apps!
heng8888
Hi, are u referring to CPU or GPU turbo? What normal apps did u use with it?
I only play some casual non-cpu or graphics intensive games. So far find not much use of this turbo function. Press on the button also no pop-up screen, not sure is it activated or not? How to use it ah? Many thanks!!
ccmheoa
To activate the turbo you need to add the app in game suite first , eg Microsoft edge then when you press the button only will activate
boaboy
After updating the firmware, all my default ringtone n alarm clock ringtone cannot be used. Anyone experienced this ?
heng8888
His final follow-up review after encountering the camera lens dust issue (see #433 )... :o
