Ok GPay works. Tried at McD.
Posted from PCWX using RVL-AL09
Somehow this phone is a lot smoother than honor play, even though same CPU
Turbo can be enabled even on normal apps!
Ok I also managed to add my dbs & ocbc cards to Google pay, but not able to verify the uob card. So, maybe the card matters too, not the device..
Hi, are u referring to CPU or GPU turbo? What normal apps did u use with it?
I only play some casual non-cpu or graphics intensive games. So far find not much use of this turbo function. Press on the button also no pop-up screen, not sure is it activated or not? How to use it ah? Many thanks!!
Which specific cards are these?
To activate the turbo you need to add the app in game suite first , eg Microsoft edge then when you press the button only will activate
After updating the firmware, all my default ringtone n alarm clock ringtone cannot be used. Anyone experienced this ?
I did. Why????Did you guys get your set from aliexpress?
Sent from Samsung Note 8 using GAGT
thanks. Besides the plug, any diff between the CN and EU version?I did. Why????
