2018 Google Pixel 3 and 3XL...πŸ˜—πŸŽ‰πŸ˜΅
lorettatay
Anyone using this case? Intent to use for my 3xl. Quality is like ringke.
Sent from HUAWEI Mate 20 Pro Emerald Green using GAGT
limmk
Was using Pixel 3XL for a while. Now I'm too used to swiping on the top left part of the status bar that when I switch to Pixel 3, Im constantly swiping my front cameras and smudging them with my fingerprints.
Must change habit or face cleaning front cameras quiet often :s13:
orange_20
ordered a white 3 XL and indigo fabric case on Google store! haha. was contemplating between pixel or 6T. finally went with pixel
any recommendations for a good clear hard case or full screen/full glue tgsp? white stone is too expensive for me.
hodiyang
My Pixel 3XL bottom speaker suddenly had static and muffled sound on all volume. Do you think going down to CTDI can do an exchange?
shiyuan
hi all, new member here is pixel 3 64gb. got the most basic and black. i'm a sucka for black.
any good screen or cover to recommend?
laughingPANDA
but actually like on my current one plus one handed use no issue without one handed mode. Google keyboard can shrink to side, then use reachbility app can easily access the top of the phone
but the thing about pixel 3 is if wanna use default navigation, the back button is on the left side
:s22:
Hahah whichever you go for it's still a pixel! Pixel users are just after stock Android and the superb camera haha so either big or small will still have it heh!
laughingPANDA
I just redeemed the code for the case. Will receive it in 2 weeks time. Pixel stand end of the month. Thanks for the heads up earlier! πŸ˜‰
You're most welcome! The case feels quite high quality. It's a 2 piece case, the inner layer will have the color you selected and the outer one with the picture you want them to print. But $70 is definitely overkill haha, if it wasn't free I'll never ever buy it LOL.
limmk
Google Pixel 3 XL Case Ultra Hybrid S
https://www.spigen.com.sg/ad/p3xl.html
Whitestone Dome Glass for Google Pixel 3 / 3 XL / 2 XL
https://www.qoo10.sg/item/WHITESTON...-SCREEN-PROTECTOR/610128696?selectedOptions=;
Google Pixel 3 Case Slim Armor Crystal
kryptonit3
drop them a call.. though static muffled sound is a known issue on 3xl since launch..update Dec patch and see if there is any improvement.
NeonX
Really happy with the size tbh. If they can squeeze in another . 5inch of display would be perfect.
Not a big fan of the pill navigation on Android Pie, much prefer the OnePlus swiping gestures. So far so good, just that my Whitestone side glue is peeling off a little
Sent from Google PIXEL 3 using GAGT
kEvinErd
The unique proposition of the Pixel 3 is its size, which is very very rare in the industry right now. Even with the Google Fabric case on, the phone still feels very manageable in the hand. I wouldn't want it to be any bigger. If I want a bigger one, I would go for Pixel 3 XL.
jeremysv
Did you apply the WSD yourself? peeling off from the exposed loca glue at edges?
kEvinErd
