sansanjikikut
- Sep 26, 2015
White label all crap formulas...they exist just for business purpose.
I see. Thanks.From my previous experience, your hair will harden after applied.
i have a lot of gel pomades and i own only 2 waxs so far (arcadian matte paste and stickmore). i would say all gel pomades needs to restyle with a bit of water or u will have a hard time if u restyle it like wax/clay products.Follow up from my previous post about Gerson and Co. Original pomade
Spoke to someone who is an experienced Gerson user - he claims that I'm using the product wrongly. U have to have it restyled with wet hands / comb in order to reinforce the hold, otherwise you'd just be breaking it apart like dried glue.
Might try this method if i choose to try the product again some time down the road. Does anyone here who has experience with gel types know if "wet" restyling is a must? I've personally used another local brand's gel type and have had much better luck restyling with dry hands though.
gel pomades are a whole new learning curve compared to waxs. i didn't like it at first, it's an acquired taste. but it started to grow onto me due to its reliability and sleekness.
i have a bottle of g&c too, works well with me in this weather, would describe it as matte sleek.
hmmm i see... i do own a couple of gel pomades that doesn't need wet restyling even for a few hours but the hold is quite bad. but eventually, still need to wet restyle if it hardens up. really depends on how long it has been set on your hair. unless u are referring to oil based like goon grease, water based types will harden unless there is some oil in there.Hmm I've just spoken to others and they haven't had to use "wet" restyling based on their experiences tho - since the hold and product presence was already there to begin with. But we'll see what others share.
what do u think of oil based pomades? Are there any other brands u can recommend apart from goon grease?
Anyone know if Indian clay will harden in the hair or will feel soft?
Is it malleable? Thanks.
If youre referring to gel pomade like "hardening", then no. But the product feel itself is pretty stiff to begin with, so expect plenty of resistance during application and re styling. But that's a tradeoff for its mad hold - still the product with the highest strength to weight ratio that I've tried.
If hold is your only priority when it comes to a product, this fella is the one for you. Brute strength, weightless. Boom.
Hi
Have about medium long hair ( fringe till nose) and behind maybe 1 inch shorter.
I am looking for a product (no magic here) but something suitable for thick wavy hair to comb all back. Something that can resist the sweat heat etc and lightweight .
Any recommendations?
Ive tried anchor clay (blue one), firsthand clay, MM balm and nothing really suited where I can arrange back in place with hand or comb. Any recommendations? I've tried pomade base and I think alot just melt in the heat. Cheap ones ex ones.
Who uses dry shampoo here? For guys?
Hi
