iPhone 11/11 Pro Accessories Show Case Thread
Eidekos
Bitten by the GWW fever. Got my case from lazada.
Im using both apple and nomad but will let apple saddle brown go for this. Felt good as bottom is covered. Solid case abit tight to remove as well. Smells good also 👏🏻👌🏼 LOL
Nwadkh
Is it tough to remove? I rem I had this casing from spigen, probably the liquid crystal. It was such a hassle to remove. Want to get a transparent case, spigen seems the most economical but worry about removing
Spigen liquid crystal for $15 on shopee / lazada!
foxriver
Have been using liquid crystal for my previous iPhones, it’s easy. The one which is tough should be hybrid, due to the back made of hard plastic.
jungon
Which shop from Lazada?
argentinafa
I see so many of you bros go for powerbank. 11/Pro/Max battery life is so good, still will fall short of Low battery syndrome outside? Can charge in office/home?
My thinking is, over reliance on powerbank will heat up the phone battery which is not good.
jameslys
iMos iPhone 11 Pro Max Sapphire Lens Ring Camera Protection Paste iPhone 11 Pro
Anyone using this? Any comment?
