M1 RT-AC2600 Router
blackbankai
You just need one of the RT-AC2600 users to feedback whether the router has VLAN presets for SingTel ONT.
If you are using ONR, than any router can also do the job.
I am currently using this RT-AC2600 with M1 500mbps fibre internet.
I have noticed that there are some presets Singtel, M1 profiles at the initial setup. Cannot confirm if the VLAN profile for Singtel works out of the box.
Hafi
I agree AC1200G is crap. So unstable. Hopefully AC2600 works better.
AC1200G works well for me as an AP bridge but its build quality is so crap that few activity LED light blink intermittently and some not working already. :(
iduncheckmail
Any user using this M1 exclusive router?
I am also interested to know whether this router support AiMesh.
in the weblink provided and pics on carousell, doesn't seem like it support Aimesh. Being exclusive to m1, those third party firmware like ddwrt also unlikely to support.
Nonetheless, based on prices on carousell, it still seems like a good buy. Unless you die die want AiMesh, then get ac68u or ac86u betta.
oakhub
Can I check if this is better than Linksys EA8100 in terms of features and signal strength? Gonna install it in my 4 room flat. Trying to see if one router will do the job.
iduncheckmail
if you are able to place the router in a high position in the center of the flat then either will do fine.
If you cannot, then need to consider other options like AP, mesh, wireless bridge etc.
oakhub
Thanks. Will try it out and see how.
sigh
It's a budget device. No Aimesh.
https://wikidevi.com/wiki/ASUS_RT-ACRH26
CPU1: MediaTek MT7621AT (880 MHz, 2 cores)
FLA1: 128 MiB (Macronix MX30LF1G18AC-TI)
RAM1: 256 MiB (Winbond W632GG6KB-15)
Expansion IFs: USB 3.0
USB ports: 1
WI1 chip1: MediaTek MT7615N
WI1 802dot11 protocols: an+ac
WI1 MIMO config: 4x4:4
WI1 antenna connector: none
WI2 chip1: MediaTek MT7615N
WI2 802dot11 protocols: bgn
WI2 MIMO config: 4x4:4
WI2 antenna connector: none
ETH chip1: MediaTek MT7621AT
Switch: MediaTek MT7621AT
LAN speed: 1G
LAN ports: 4
WAN speed: 1G
WAN ports: 1
kuma-mon
Hmmm, if there are singtel presets i guess it will work for singtel as well...i hope. I'm using singtel fibre and I just bought one from carousell. Hopefully it works. :s13::s13:
iduncheckmail
USB ports: 1
LAN speed: 1G
LAN ports: 4
WAN speed: 1G
WAN ports: 1
Hmmmm MediaTek chipset ......
Phen8210
oh wow, M1 is now giving this router from now on, instead of AC1200. Good to have an upgrade. But bad news, it will soon flood the market. Just like the AC1200, Carousell has tons of people selling but can't be sold even at $50.
Lol, isn't that a good thing. Can get decent router at low price. For equivalent models at least $150++.
I will even buy it as a standalone AP.. in few months time sure $40-70 rofl.
davpiyo
After I google my router RT-N12D1
CPU:
Broadcom BCM5357C0
CPU Cores:
CPU MHz:
300
Flash MB:
8
RAM MB:
32
I use 4 years already not bad and the spec so low.
Feel like upgrading to RT-AC2600 Router
eBuddy
How's the performance of this router on Singtel Fiber network? I am currently using Linksys EA8100, wonder this Asus router perform better?
