Huawei mate 20 X discussion thread
laeticia
Does anyone know what this icon means? It's driving me crazy having it appear in the icon space
1982-1994
Square Screen and Wi-Fi Icon
This icon basically means that your Android device is casting via wireless to another device that is connected on the network, like an Android smart TV for example. If you have this icon set up on your TV, then simply go over to YouTube and play a video and it will automatically appear there. This technology is known as Google Chromecast.
laeticia
Ooh thanks, the icon is gone now for some reason. I don't know anything about casting so not sure why it was on.
arsynyc
After updating to Emui 10, WiFi keep dropping, Bluetooth sometimes don't autoconnect to headset, after listening to music a while sometimes connection break... The list goes on...
Sent from HUAWEI EVR-L29 using GAGT
1982-1994
Try factory reset and if problem persist, can consider downgrade to 9.1
Shib
Can try the diagnostic or reboot and see. Most of the time, reboot helps.
kelvinti
Yes. A re-setup of all connections helps too. Wifi, Bluetooth, NFC, bla bla bla...on both the 20X and its connected devices. :)
eyz
I realised my auto-rotate is not as sensitive as before. sometimes when it rotate to landscape, when I turn back, it doesn't go back to portrait.
kelvinti
It is! Well! Being the 1st version, it is not that polished yet! Just wait for the next 2 versions.:s22:
Huawei firmware update is quite a fast and furious one! :)
rainbow99
Not sure if I'm the only ones having the problem. Trying Android 10 and Nova launcher. Noticed that under recent, the tiles usually not able to load correctly. For example a tile showing Spotify can actually be WhatsApp app when clicked. It seems the tile visuals are not generated correctly
Sent from M20X using GAGT
eyz
hopefully. sometimes quite irritating. need to go back to home screen or turn auto-rotate off and on again.
mie28
Didn't happen for me. Is there a pattern or just randomly? Usually, I don't use auto-rotate. If I rotate and need to flip it, I just manually use the icon at the bottom navigation bar. Quite OCD on this rotating thing. 😁
mie28
This is the recent menu from the Apps list? Mine seems to work fine the icons are correctly launching the right apps. Initially there was some issues with Nova and UOB I suspect. I set the launcher back to Huawei's then back again to Nova. Or you can try to backup the settings, reinstall Nova and load back your settings?
mie28
Just to confirm, the front facing camera usually makes the photo if the foreground people blurred right if you take groupfies, even if the mode is not set to portrait and all those face effects have been turned down to zero. I can't take group photos, the back people always kana blurred out. End up use other brands. Even use P30 like that.
Archuke
For me, that only happens in portrait mode. Think you kena bug
rainbow99
Yes I meant the recent menu. Ok will try your method, thanks much for sharing.
kelvinti
Mate 20 x screen is perfect size for me and battery can last long
Absolutely so! It is likes once you have driven a huge BMW 7 Series, you forever can't drive a smaller BMW 3, 4 or even 5 Series anymore...:s22::s8:
