Mecisteus
- Jun 16, 2002
Hi. I have a 6 year old Daikin System 3 in a fully rented flat. It was installed with 2 fcus but a third was added late last year. Soon after, there was a drop in coolness. Called the installer to check on the pressure (of the 3rd fcu) but it was fine. About a month or two later, same case. This time I changed the pipings for the older 2 fcus. Two months later, all units not cold. Quite headache as just yesterday, tenant called and say the compressor not working.
Question is: Do I try to rectify the compressor knowing at the back of my mind, there may still be issues with leaked gas down the road or do I just change to a new system. And if I do, should I retain the new pipings? I called 2 different companies and both can't pinpoint if there is really a leak or not.
Added info: Last tenant really whacked the air con. Used them almost 24/7. I know coz the bills were in the 300 - 400 range a month.
That's the problem with these tenants.
If you don't warn them, they will switch on 24/7.
I warn all my tenants to limit usage.
What you can do is to do an overhaul with non-inverter aircons from a reputable company. Plus all the pipings. I assume you have problem with pipings.
Get your tenants to be responsible for the maintenance, repair and electricity bills. Make them show you quarterly aircon maintenance receipts as proof.
Your non-inverter aircon is cheap.
