Good morning,
My residence is an EC at Punggol with LAN points in each room.
Have not got a chance to test them to confirm all working as i only found out about the points after my warranty period. Management just push away saying main con do not entertain such request after warranty.
I have tried out the followings but still fail. May I trouble anyone to point out my setup error.
My ISP is Myrepublic.
Equipment I have are:
1. Asus AC88 router
2. Asus AC56U router(non Aimesh)
3. 3 x Asus Lyra (not Mini also not Trio)
4. Dlink 8 port Gigabyte switch
First setup(all happening in DB box area):
- ONT > Dlink 8 port gigabyte ports > Lan 1 point + Lan 3 point.
This setup, Lan 1 data point in living room with AC88 as main router detecting signal. Lan 3 data point tried setup as Access Point. Plug in any of the Wan ports, encounter no internet/ some IP conflict.
Second setup(all happening in DB box area):
- ONT > AC56 router(set as Access Point) > Lan 1 point + Lan 3
This setup Lan 1 data point connecred to Main Lyra no signal.
Lan 3 wall Lan plug into laptop, showing no internet on laptop.
Current setup for me is using 2 x Lyra with ONT > modem > Lan 1 point(in DB box)
1 Lyra(main) connected to Lan data point 1 in living room, the other Lyra just power switch located in my furthest room. Covers 80% of the house at the moment.
What I hope to achieve is:
- AC 88 in living room
- Each room can have a Lyra with Lan connection when running for better speed. Current speed with 2 Lyras, Living room about 280mbps and other room running about 60mbps with room door close.
OR
All 3 Lyra can be connected to each room Lan point for better speed/ connection.
My preferred method will be first setup with Dlink switch but also open to whichever is easiest setup to achieve the same result I wish for.
May I know how shoud my AC 88 router setup should be in the living room? Router mode or Access Point mode when plug into Living room Lan 1?
Lan 3(MBR) I intend to connect a Lyra in the room Lan 3 data point, do I have to setup 1 x Lyra as Access point too?
I would like to setup/ plugin another Lyra in second bedroom(call it Lan 4) with Lan point connection, does it have to be/ can it be on Acess Point mode too?
I have seperately trying out in different days and many hours had been spent each time but no avail, I am kinda giving up already. Thanks for your advices in advance.
