Xiaomi TV Discussion Thread V [consolidated]
jfreex98
65 inch at $758 worth it?
Thinking of buying and selling away my 55" China set
i feel it's worth, $758 for a 65inch 4k hdr10+ smart tv. comparing to prism+ E65 4k smart tv that runs on linux selling at $999 which they claim it's original price is $1799 i cant help but to laugh at the marketing gimmick
Gameomi
Just received my 55" russian set. Was informed gotta wait for future updates to support the native Netflix app, not sure how long its gonna take :s27:
Anyone knows the size of the bolt for the tv mount? Tried using my previous mount bolt but it doesn't fit in.
potato_chips
Just ordered my 55' set from the mijirobo qoo10 shop. I hope they ship the proper claimed "latest" version with everything installed. Shall keep you guys posted
oinkoink1999
For those of you that bought Xiaomi TV, can you all do the Chroma Sub Sampling test :
https://www.rtings.com/tv/learn/chroma-subsampling
It is basically displaying this picture on the screen :
This image has been resized.Click to view original image
At original 100% size and then see whether can you read the last 2 lines legibly.
Do share your TV model and size also.
OK I tried and can see last 2 lines. Model 4S 65" 2020 version
Sent from HUAWEI YAL-L21 using GAGT
decibels
Icic, thanks for the advice
Shall order 1 then!!
Loser
got two sellers in qoo10, mostly order from?
I warn you first, only buy from these sellers if you not urgently need the TV. If you need the TV asap, spend a little more and order from smart_tech on caraousell or buy TCL TV.
The two sellers which are actually the same on Qoo10 and Lazada are MinihelpersSG and Mijia.Roborock. Another one of their clone is Mijia.viomi.
Most order from Mijia.Roborock for 65", other sizes can order from both.
Do what you will with the info.
gnixer
Was considering to upgrade from my 3S 65”
jtec14
I remembered someone mentioned here not possible for native netflix to work if the remote no netflix button mean no.
Actually netflix already appeared in playstore after last update but after installing, it will say not supported. So just sideload it.
Gameomi
but think sideload doesnt support 4k right
roidred
its okay to cancel and make a new order for better coupons when the item is not on delivery yet. but risk is must wait long as new order become queue in the back. later OOS might need wait another batch which will take never ending "2weeks"?
Yes i have re ordered again after cancelling. This time added the wall mount also which is what you save $90.
Dont care about delivery since i have a 32 tv for the time being.
yourxp
Is there an option or hack to enable internal speakers + hdmi-arc/optical out simultaneously? Xiaomi 4s 55" here...
Thanks
imacbie
Guys who have purchased and received the 65 inche model
And have set it up in standing mode
Check with you, what is the distance between the 2 stands?
Worried tv rack not long enough.
Thanks in advance
anyone ?? :s22::s22:
tia!
PongRareRare
Try Puffin TV browser. It's optimized for Android TV.
Not the android browser.
It's "Puffin TV browser"
Working great! Thanks a lot
