- Sep 16, 2018
Updated on 21-March-2025
1. 2.5Gbe capable routers with at least dual 2.5G ports
1) Local/Global version
WiFi 6/6E router
Asus ROG GT-AX6000
Asus RT-AX88U Pro
Asus TUF-AX6000 (China version is called TX-AX6000)
Asus ZenWiFi XT12 Pro (triband, more suitable as mesh solution with wireless backhaul)
Asus ZenWiFi ET12 Pro (triband, more suitable as mesh solution with wireless backhaul)
TP-Link Archer AX55 Pro
WiFi 7 router
TP-Link Archer BE550 (triband BE9300),
TP-link Archer BE400 (dual band BE6500),
TP-Link Archer BE230 (dual band BE3600),
TP-Link Deco BE65 (triband BE11000)
TP-Link Deco BE25 (dual band BE5000)
TP-Link HB611-SGST for Singtel users (triband BE11000)
TP-Link HB410 for Starhub users (dual band BE6500)
Asus TUF-BE6500
Asus RT-BE58U
Ubiquiti UniFi Cloud Gateway Max (UCG-Max)
2) Wired router (no wireless function)
Mini PCs with dual or quad or more 2.5G ports (many brands)
ARM development boards with dual 2.5G ports, example:
Firewalla Gold SE (dual 2.5G ports)
Firewalla Gold Plus (quad 2.5G ports)
3) China version WiFi 6 router
Asus TX-6000
Asus China TUF-AX4200Q (different from local TUF-AX4200 as it has dual 2.5G ports)
GL.iNet Flint 2 GL-MT6000 (also got international version)
4) China version WiFi 7 router
https://forums.hardwarezone.com.sg/...out-6ghz-band-support.6905228/#post-147664804
Most recommended:
Xiaomi BE7000 (quad 2.5G ports, good match for 2.5G plans): RMB799
Xiaomi BE6500 Pro (quad 2.5G ports, good for 2.5G plans): RMB699
Xiaomi BE6500 (quad 2.5G ports, good for 2.5G plans): RMB499
TP-Link TL-7DR7260 BE7200 (five 2.5G ports, good match for 2.5G plans): RMB 599
TP-Link TL-7DR6560 BE6500 (quad 2.5G ports, good match for 2.5G plans), RMB 559
ZTE BE7200 Pro+ (中兴问天BE7200Pro+, dual 2.5G ports, good match for 2.5Gbps plans): RMB 599
Asus TUF-BE6500 (quad 2.5G ports) : RMB 799
Huawei BE7 Pro (quad 2.5G port version, 512MB RAM), BE6500, RMB 699
Huawei BE7 (dual 2.5G port version), BE6500, RMB 599
2. Wireless router with single 10G port and multiple 2.5G ports
Asus RT-BE92U (triband BE9700, single 10G port, quad 2.5G ports, 1GB RAM)
Asus RT-BE86U (dual band BE6800, single 10G port, quad 2.5G ports, 1GB RAM)
Netgear Orbi 870 (triband BE21000, main router: one 10G WAN port and quad 2.5G LAN ports; satellite node: quad 2.5G LAN ports).
TP-Link Archer BE700 (Triband BE15000, one 10G port and one 2.5G port and thee 1G ports)
TP-Link Archer BE550 Pro (Triband BE9700, 1× 10 Gbps WAN port, 4× 2.5 Gbps LAN ports)
Ubiquiti UDR7 (one 10G SFP+ port and 5 x 2.5G ports)
Ubiquiti UX7 (one 10G RJ45 port and one 2.5G port)
3. 2.5Gbe capable switches
Cheap local version:
TL-SG105-M2, S$79 when on offer.
TL-SG108-M2, S$129 when on offer.
More estabilished vendors:
MikroTik:
https://mikrotik.com/products/group/switches
TP-Link Business:
https://www.omadanetworks.com/sg/business-networking/omada/switch/
Ubiquiti:
UniFi Flex Mini 2.5G Switch, Unifi Flex 2.5G, UniFi Flex 2.5G POE, Enterprise 8 PoE (with dual SFP+ ports)
https://ui.com/sg/en/switching/utility
QNAP:
https://www.qnap.com/en-as/product/compare-switches?conditions=link_speed-2_5gbe_rj45
TRENDnet
Netgear
Zyxel
Asustor
Chinese vendors:
TP-Link China 普联科技: TL-SH1205, TL-SH1205PB, TL-SH1208, TL-SH1206, etc
https://www.tp-link.com.cn/list_2503.html
Hasivo 海思视讯
https://www.hasivo.com/cpzs
XikeStor/Seeker 兮克
https://xikestor.com/
https://seekswan.com/user/pages/product-center.html
Siri-vision 希力微视
https://www.siri-vision.com/
Tenda
Mecury 水星
Netcore磊科
ONTi
感闻
联果LianGuo
JT-COM 景唐
More options:
https://www.servethehome.com/the-ul...gear-hasivo-mokerlink-trendnet-zyxel-tp-link/
4. 2.5Gbe network adapters:
Now this becomes kind of commodity. You can get USB 3 Type A or Type C to 2.5Gbe network adapter, or PCI-E based 2.5Gbe adapters (including multiple 2.5Gbe adapters) easily.
5. Related threads
10G capable router and switches without SFP+ ports
https://forums.hardwarezone.com.sg/...and-switch-rj45-version-no-sfp-ports.7072646/
10G capable Router and switch with SFP+ ports.
https://forums.hardwarezone.com.sg/...port-switch-and-vq-xgs-pon-onu-stick.7047645/
5Gbe/10Gbe network adapters
https://forums.hardwarezone.com.sg/threads/1gbe-and-beyond-ethernet-adapters.7068236/
WiFi 7 router (some of them are 10G capable, many of them are 2.5G capable)
https://forums.hardwarezone.com.sg/...-7-routers-without-6ghz-band-support.6905228/
Network and WiFi configuration for 5Gbps/6Gbps/10Gbps plans
https://forums.hardwarezone.com.sg/...urations-for-5gbps-6gbps-10gbps-plan.7073159/
Home Lab and 10G Home Network
https://forums.hardwarezone.com.sg/...projects-include-10g-network-upgrade.6341518/
WiFi 6/6E router
Asus ROG GT-AX6000
Asus RT-AX88U Pro
WiFi 7 router
Asus TUF-BE6500
Asus RT-BE58U
Nano Pi R5S, R5C and R6S;
Banana Pi BPI-R3 (dual SFP 2.5Gbe optic ports).
Asus TX-6000
Most recommended:
MikroTik:
TP-Link Business:
Ubiquiti:
QNAP:
TRENDnet
Netgear
Zyxel
Asustor
Chinese vendors:
Hasivo 海思视讯
XikeStor/Seeker 兮克
Siri-vision 希力微视
Tenda
Mecury 水星
Netcore磊科
ONTi
感闻
联果LianGuo
JT-COM 景唐
More options:
5. Related threads
