Here come the mi 10 ultra and k30 ultra!
Joe2020
I do have problem with my microphone. During whatsapp call(loudspeaker) or in game communication, receiver side sometime unable to hear my voice.
I wonder if you guy pass the CIT test(multiple click on kernel version) for top mic at normal distance? As mine only pass when I speak loudly at very close distance.
deckcard
Are u able to disable sougu keyboard? If u can, then it will default to the available keyboard u installed. Worst case scenario is to use adb to disable it
kwekyx
btw, has anyone tried using 120hz screen for a whole day? how does battery life hold up? interested to know hehe
jackycar
Which seller is the cheapest now for mi 10 ultra 512gb? Finer on Qoo10 seems to be a bit ex at 1629, shopee has one seller at 1529, Lazada in the middle at 1569..
I should wait for 10/10 to buy with voucher on Shopee or Lazada Yea?
gapboy
Was cheaper 9.9 sale. Guess you missed it was around 1.2k+
kimwee
Anybody having issue with WhatsApp contact sync? Mine dunno y the sync not working properly after a while will stop showing the contact names then I need manually refresh.
KeYoKe
Got set allow all permissions for whatsapp app?
doki81
no such issue as long as you grant the contact and other permission...miui just too strict on these permission thing.. even stricter from samsung.
Sent from Xiaomi M10Ultra using GAGT
gapboy
i suspect miui optimization issue too .. once i on it works fine..
Zantesuken
I had this issue too. What I did is go into settings>app>permission>read your contacts and set to always allow. Then settle liao
kwekyx
random other question regarding whatsapp on mi10u. anyone noticed that their recent emojis on whatsapp always gets reset to nothing?
