GVGT: US 155mm Paladin Howitzer now can shot down a cruise missiles!!
tankgunner
Mentor
our own 155mm can or not? :eek:
https://www.popularmechanics.com/mi...-army-howitzer-shoots-down-simulated-missile/
A U.S. Army howitzer successfully engaged a simulated cruise missile, shooting it down with a projectile traveling at Mach 5. The howitzer crew was assisted by a new U.S. Air Force battle management system. The test is the result of a Pentagon program designed to take existing weapon systems and modify them to take on new and important roles.
The intercept took place at White Sands Missile Range, New Mexico. In a key test for the Air Force’s Advanced Battle Management System (ABMS), B-52 bombers launched six BQM-167 “Skeeter’ aerial targets. The “Skeeters” served as a stand-in for a salvo of low-flying cruise missiles.
Air Force sensors detected the “cruise missiles” and then provided targeting data to a F-16 Fighting Falcon fighter and MQ-9 Reaper drone equipped with AIM-9X Sidewinder air-to-air missiles, a ground launcher, a U.S. Navy 5-inch deck gun, and U.S. Army M109A7 Paladin self-propelled howitzer.
gravity_infinity
they refitted with a Precision ai chip and sensor to change the whole defense ballgame
gravity_infinity
Slow firing rate and cannot fire on the move
:s8:
precision firing. ok since rate of fire is better or equal to missiles.
also. cheap.
it is a moving turret that has precision aiming to hit incoming missiles.
its very cheap compare to other anti missiles defense system.
Apparatus
Re
Anti-tank avaition cluster bombs will wipe ou the whole group of tanks
The chinese has a tank version with greater fire power to penetrate tanks, rapid firing on the move and able to handle the anti-tank avaition cluster bombs
:s13:
tankgunner
Mentor
also. cheap.
actually how it works?
the round burst in the air to create a curtain of shrapnel to destroy the incoming missile?
or its going to be a impact kill?
gravity_infinity
it hit onto the missile if i am not wrong. it is precision aiming via the refitted high tech sensor and the AI chip in precision calculation, calculating the angle of engagement, the point it need to fire and the direction it has to travel.
tankgunner
Mentor
but a 155 round can't travel very fast and far right?
KenQuek
This is why space force is important. If China take down satellites all the tech become paperweights.
Will be super epic if Elon Musk offers his satellite constellation when that happens.
Prismatic
A bit confused with the article, so the target was Mach 5 or the projector the Paladin fired was Mach 5?
Because Skeeter target drones are sub-sonic aircrafts, just like most cruise missiles (some even slower than the Skeeter).
Not trying to downplay the tech, but it's going to be a lot harder to shoot down supersonic or hypersonic missiles which everyone seems to be developing. Last I heard, some countries were designing cruise missiles that could avoid AA systems.
Libbis
Is a howitzer crew. Take down a third of the crew, the formation failed.
rachdanon
Urmmm...we are in the age of Hypersonic missiles. Russia just implemented such a missile that travels at Mach 20. There is no missile defense system against such missiles.
China is next and US is in 3rd position, only likely ready in mid 2020s.
I think it is likely why US said their support of annexation for Israel is 2024 at the earliest.
tankgunner
Mentor
a typical tank shell travels at 2km per second.
much faster than many missiles. u seen a tank fired a round before? its fast.
for a APFSDS round its fast. your eyes can't really see it flying......
but for a HE round, you can see its entire fly path.
not sure about 155 thou.
need to ask the arty guys liao.
