With AIA premium increase by 100+ again, is it still worth it?
decibel.
The rider for hospitalization plan when I started is only 600+ but it raised to 800 few years back now increase again.
Sent from HUAWEI VOG-L29 using GAGT
decibel.
U sure is not because your age band is different now?
No I'm still in same age band that's why it's not feeling good given that they only just increased not long ago.
winthony
It depends actually. If you are on the 100% coverage ISP, whichever provider you go now you will be subjected to co-payment/co-insurance even with rider.
Now if you are ok with that, the other pre-req is that you do not have any preexisting else it would be an issue!
If you are comfortable with forking out certain amount of $ in the event of hospitalisation and you are healthy, there are plenty of options for you :)
decibel.
Yeah I'm still on 100% one of the main reason I didn't change but it seems like AIA just happily leverage on that fact to keep increasing premium?
reddevil0728
I don't think is just AIA.
The_Davis
High Honorary Member
Deluxe Member
Where did you see the increase?? I thought just got increase a couple of months back?
decibel.
I didn't check on other providers but if that's the case then
everyone is just going to take advantage of the situation.
Max Essential A rider. My premium is due end of year. The last increase I had was 1 or 2 years back when everyone still on 100%. And my age band is still the same. All citing increased hospital costs. Now is close to 1k
reddevil0728
The_Davis
Deluxe Member
Makes sense. I had received this about 1 month prior to my premium payment.
I am on HSG max a. Premium jump alot also (
xtwis7
There’s always the option to switch to the 5% copay plans.
decibel.
That's medishield life increase. My cash component increase as well.
So you keeping it?
Worth it meh? 5% co pay like quite heavy?
winthony
So you keeping it?
If you have a rider, it would be capped at $3k annually so your max out of cost annually would be $3k for medical cost if there is any unfortunate event:)
Stallone
thats the problem with insurance
when u need it most during ur 60s, u likely cant even afford the premium
so wad's the pt of paying the past 30yrs then?
