i1magic
- Dec 11, 2002
Is your NAS using 2.5Gbe as well? If it has only gigait Ethernet, then no point using the Realtek 2.5Gbe card, get an Intel gigabit Ethernet card for more stable operation.
However, if your NAS got 2.5Gbe, then be careful the first generation Intel I225 V1 based 2.5Gbs Ethernet card is having big problems. Not so sure if the new silicon revision I225 V2 is already in the market or not.
https://forums.unraid.net/topic/99261-25gbe-intel-z490-vs-amd-x570/
https://wccftech.com/intel-400-series-chipsets-z490-i225-v-network-controller-issue-fix-2h-2020/
Intel is saying you need compatible router/switch to use the I225V1 card as a 2.5G adapter, if not, use it as gigabit.
https://www.intel.com/i225v1
So if you do not want to use Realtek 2.5Gbps Ethernet card, then use the more expensive Marvell AQC112C (2.5Gbe) or AQC111C (2.5Gbe/5Gbe) based cards.
More info about 2.5Gbps Home Network here.
https://forums.hardwarezone.com.sg/...-4/2-5-gbps-wired-home-network-6347648-5.html
No lah. Synology so stingy with features, so far no models got 2.5Gbps LAN port right? Only got port aggregation. But if router doesn't support 2.5Gbps, also no use.
As much as I would like to have 2.5Gbps, don't think it will happen until 2.5Gbps becomes mainstream for router.
I really didn't notice much on NIC until now. My previous rig is with Gigabyte motherboard and it was ok.
I decided on the MSI MAG Tomahawk X570 because it was like $30-$40 more than MSI B550 Tomahawk and it comes with Wifi6 + BT. Plus this motherboard has super good review from "Hardware Unboxed".
