Unless you need >8GB, this is ok.
Thanks! However the link has 16GB options, those are not good value? May I know why you mentioned unless need >8gb?
Continue to run the old hardware with a new/second hand motherboard from taobao. Still can find quite a lot of them. Good old server, I find it a waste to retire them.....some for sentimental value.
Most of my servers/systems are constantly brought/resuscitate back to life with "new" old hardware. Motherboard usually the first to up lorry. Easily get on the cheap from ebay/taobao. Surprisingly Convergent still honor my Kingston Value DDR3 (lifetime limited warranty) when it kaput after 9 years of service!![]()
True true, still looking high&low in taobao for pairing my existing Lian Li PC-Q18 (mini-itx) case.
If $$$-no-object, would love to go for those supermicro's embedded Atom C3850 with Quad LANs![]()
https://www.reddit.com/r/homelab/comments/m5x946/fyi_you_should_probably_avoid_using_wireguard_on/
https://lists.zx2c4.com/pipermail/wireguard/2021-March/006494.html
PSA: Probably shouldn't be using pfsense's implimentation of kernal mode wireguard if you're using it.![]()
WireGuard Removed from pfsense
*Stop using WireGuard on pfsense until further notice.
NOTE: I have also removed the implementation of WireGuard on my threads.
Quite dramatic, i guess in a opensource world, thats bound to happen alot.
)Quite dramatic, i guess in a opensource world, thats bound to happen alot.
Hi I have a basic question, am trying to build a DIY pfsense router but just want to check if I can still watch Starhub IPTV, specifically for the FTA channels which apparently would only work if only directly connected to the issued Nokia or Linksys routers? Thanks!
Are you using the Starhub TV+ Box with the Starhub TV+ Pass and Starhub Fibre Internet? In that case, yes, you need to use the Nokia Beacon 1 (wired or wireless, one of the worst free router from ISPs), Linksys EA7500 V2 or EA8100 (wired) to get FTA channels directly on the Starhub TV+ box (said to be laggy)
Unless someone reverses engineering the protocol of the FTA channels it will not work with pfSense.
Solution is actually easy if you are okay with the following two options.
1) get a digital tuner box and antenna. You may need only an antenna if your TV has the DVB-T2 tuner built-in.
2) using MeWatch and cast from mobile phone.
Thanks xiaofan, yes sorry forgot to mention I’ve recently recontracted with the new StarHub TV+ with Nokia Beacon (100% agree it’s very very subpar). This is really quite saddening as I was really looking forward to building a DIY pfSenserouter, or in fact just putting any routers upstream (excited about flashing DDwrt Openwrt firmwares too) but have had too many hair-pulling moments when the FTA channels were somehow “blocked”, now that I have more confirmation on the flaw in the setup, will need to plan again. Thank you for the suggestions as well, actually MeWatch is definitely a viable option, will look into it, sorry for hijacking the thread too.
It is ok. The thread is to help forumers. Feel free to drop by when you have the chance to DIY your pfsense router again.
*BTW I saw your earlier post but did not reply because I am not the "best person" to answer your question. Do not want to provide you with the wrong info.
